Solved 3CX Wallboard is empty
unkhum
Forum User
Wallboard and Q-Manager don't show the queue statistics.
Hello @unkhum
Is your extension a member or a manager of a queue?
Yes, my extension is queue manager.
What PBX version are you running? You can see the exact build number on the Dashboard, under the Information column next to the licence version. For example 15.5.15502.6.
Also can try try refreshing you licence activation? If that does not fix the issue try restarting the PBX services.
It was fixed after restarting the PBX services.
Thanks.
Glad to see the issue has been resolved. Keep an eye on it and let us know if it happens again.
Rhameez
