- Joined
- Jul 5, 2024
- Messages
- 66
- Reaction score
- 26
I integrated 3CX into a hotel while keeping the existing analog phones connected through Grandstream GXW4232 gateways.
Some phones have function keys programmed with legacy 4-digit codes (front desk, restaurant, bar). Unfortunately, I was not informed of this requirement before the migration.
The new 3CX system uses 3-digit extensions, so these programmed codes no longer match the destination extensions.
Is there a way to map these legacy 4-digit codes to the correct 3-digit extensions without reprogramming all analog phones? Like using 3CX Call Flow Designer (CFD), a 3CX dial plan/routing rule, or a digit map on the Grandstream GXW4232 to translate the dialed digits before they reach 3CX.
What would be the cleanest and most maintainable approach in a 3CX environment?
I have an AI license there.
Thank you all !
Thank you all !
