4SC License, Maintenance, Activation Expired Confusion
buggycode
I have an "On-Premise" "self-hosted" (Debian 10) system. Yes is was installed from a repo and not an ISO. (Please do not flame me on how bad this is etc etc - I know and I have reasons why I chose this route when is was initially installed - this system has been working almost flawlessly for some years now)
However recent changes have made this system only partially functional. The following is happening:
  • We notice the 3CX Phone app is not responding at all (I have checked, it is the latest etc etc)
  • When I log into my server I see:
    • The server is showing a message: Your Subscription expired on 12/31/2023. Without subscription you lose access to important features
    • Maintenance has expired: Updates not available
    • Cannot connect to activation.3cx.com
I have not received any email regarding major changes to the license, maintenance etc. Now the system ins only partial working.
From what I have read, I need to be on version 18.08.x currently I am on 18.07 and cannot update further.
I am running a 4SC type license - that is all I need.
I activation service is not accessible possibly due to the outdated version.
For now I need to continue using this service - how can I update to 18.08? What are the next possible step to get this service running correctly - a full installation is not on the possible at the moment.
King Regards
Gerhard
The safest way here is to re-install with the latest V18 ISO.
I agree - and that is what I am trying now (despite what I wrote before).
However, using the download links withing the "on-prem" installation guide, I am directed to a Debian version 10 iso. I thought this should new be Debian 12? Secondly upon install - which appeared to be with out issue, a reboot did not end up in the 3CX install, but a standard Linux prompt! Now installer found, and it used the standard Debian repositories. It is using Debian 10.13
I do not think that is supposed to happen
Regards
Gerhard
V18 is in Debian 10. The new V20 is in Debian 12 and the repositories of the ISO are the 3CX repositories.
I think I caused the problem myself - I usually install Debian in advance mode if I am not automating the install. This probably prevented the re1uired 3CX packages / changes from installing.
I re-ran the installation in standard mode - appears to to hav3e worked so-far.
Regards
Gerhard
However it still does not as
King Regards
Gerhard
Take a look at https://www.3cx.com/blog/news/4sc-free-update/
And
https://www.3cx.com/community/threads/3cx
And
https://www.3cx.com/community/threa...ection-to-activate-3cx-com.122087/post-586936
The supported method is to install 18u9 and restore from backup, but see if those help.
Given your installation method I would not be confident it will upgrade to v20…
-v18u5-failed-to-establish-a-tcp-connection-to-activate-3cx-com.122087/post-586936
Thanks for your reply.
I am hoping that I can continue to run this "on-prem" myself. This is for a small business - < 5 users and have not intention of hosting this anywhere. I am very confused by the "free-forever" statement - it really isn't, especially if I run the server myself.
I downloaded the ISO.
After a bit of fiddling the installation appears to have started correctly. I now have version 18.0.9 on Debian 10. Restored from a backup and now need to configure the firewall rules as it is a different IP address.
It appears, in order to continue use the license old free 4SC license, I need to upgrade to version 20 before March or I will end up in this situation again. I am going through requirements, and again not sure about some email/owner requirements. I run this on behalf of a business which has a different domain. However I am the 3CX system owner and admin so it should be OK. I run my own DNS so the split horizon DNS should be OK too. I just hope this license keeps going for a while. I would like to continue using 3CX in its current state. The paid version provides services and function I just do not need.
Regards
Gerhard
Since this is a small business as you mentioned, i would also suggest to consider the SMB solution. Check this blog post for more information.
arming
