*9 Voice Call Not working
Tim Blount
I can't get *9 to work. below is the log:
11/20/2019 9:36:07 AM - L:2834.1[Extn:610] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=771729284 [email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.10:5060;branch=z9hG4bK771729284
Contact: <sip:*[email protected]:5060>
To: <sip:*[email protected]:5060>;tag=7f48a240
From: "Corina Martinez"<sip:[email protected]:5060>;tag=3164908177
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 16.0.3.676 (676)
Content-Length: 282
v=0
o=3cxPS 518348865536 395975852033 IN IP4 192.168.1.2
s=3cxPS Audio call
b=AS:84
t=0 0
a=X-nat:0
m=audio 42000 RTP/AVP 0 101
c=IN IP4 192.168.1.175
b=TIAS:64000
b=AS:84
a=rtcp:42001
a=sendrecv
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
11/20/2019 9:36:07 AM - L:2834.1[Extn:610] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=771729284 [email protected]:
SIP/2.0 200 OK
CSeq: 2 INVITE
Content-Length: 282
v=0
s=3cxPS Audio call
b=AS:84
t=0 0
a=X-nat:0
b=TIAS:64000
b=AS:84
a=rtcp:42001
a=sendrecv
a=fmtp:101 0-15
11/20/2019 9:36:07 AM - Call(C:2834), Extn:610 on exit: DlgInfo(2834-3496/Confirmed / I)
11/20/2019 9:36:07 AM - Call(C:2834), Extn:610 on entry: DlgInfo(2834-3496/Early / I)
11/20/2019 9:36:07 AM - Notify dialog-info: Extn:610: sip:[email protected]:5060, Call(C:2834)
11/20/2019 9:36:07 AM - L:2834.1[Extn:610] has been connected to L:2834.3[Extn:634]; SDP state - GotOffer
11/20/2019 9:36:07 AM - L:2834.1[Extn:610]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
11/20/2019 9:36:07 AM - L:2834.3[Extn:634] has joined to L:2834.1[Extn:610]
11/20/2019 9:36:07 AM - L:2834.1[Extn:610] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=771729284 [email protected]:
SIP/2.0 180 Ringing
CSeq: 2 INVITE
Content-Length: 0
11/20/2019 9:36:07 AM - Call(C:2834), Extn:610 on exit: DlgInfo(2834-3496/Early / I)
11/20/2019 9:36:07 AM - Call(C:2834), Extn:610 on entry: DlgInfo(2834-3496/Initial / I)
11/20/2019 9:36:07 AM - [CM503025]: Call(C:2834): Calling T:Extn:634@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:49329;rinstance=0-36cffae873a94e9cb487f974ca2814f8;ob] for L:2834.1[Extn:610]
11/20/2019 9:36:07 AM - [Flow] Call(C:2834): making call from L:2834.1[Extn:610] to T:Extn:634@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:49329;rinstance=0-36cffae873a94e9cb487f974ca2814f8;ob]
11/20/2019 9:36:07 AM - [CM503027]: Call(C:2834): From: Extn:610 ("Corina Martinez" <sip:[email protected]:5060>) to T:Extn:634@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:49329;rinstance=0-36cffae873a94e9cb487f974ca2814f8;ob]
11/20/2019 9:36:07 AM - [CM503004]: Call(C:2834): Route 1: from L:2834.1[Extn:610] to T:Extn:634@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:49329;rinstance=0-36cffae873a94e9cb487f974ca2814f8;ob]
11/20/2019 9:36:07 AM - L:2834.3[Extn:634] Sending: OnSendResp Send 415/MESSAGE from 0.0.0.0:0 tid=Pj7c8785266be9461dac37a93cfcfc8e84 Call-ID=8wQbUumTusWOegc1fOFUuw..:
SIP/2.0 415 Unsupported Media Type
Via: SIP/2.0/UDP 192.168.1.175:49329;rport=49329;branch=z9hG4bKPj7c8785266be9461dac37a93cfcfc8e84
To: "Corina Martinez"<sip:[email protected]:5060>;tag=1b528926
From: <sip:[email protected]>;tag=091cee2034d940bcbd34eec64f2f0960;intercom=true
Call-ID: 8wQbUumTusWOegc1fOFUuw..
CSeq: 23814 MESSAGE
Content-Length: 0
11/20/2019 9:36:07 AM - L:2834.3[Extn:634]Rejecting chat channel request. Party does not support 3CX chat over SIP MESSAGE.
11/20/2019 9:36:07 AM - L:2834.3[Extn:634]Message from <sip:[email protected]>;tag=091cee2034d940bcbd34eec64f2f0960;intercom=true to "Corina Martinez" <sip:[email protected]:5060>;tag=1b528926:Chat Recv Req MESSAGE from 192.168.1.175:49329 tid=Pj7c8785266be9461dac37a93cfcfc8e84 Call-ID=8wQbUumTusWOegc1fOFUuw..:
MESSAGE sip:[email protected]:5060 SIP/2.0
Max-Forwards: 70
To: "Corina Martinez" <sip:[email protected]:5060>;tag=1b528926
CSeq: 23814 MESSAGE
Accept: text/plain, application/im-iscomposing+xml
Content-Type: x-chat/control
Proxy-Authorization: Digest username="634",realm="3CXPhoneSystem",nonce="414d535c13e5ee6787:1e34bf39cb7c6e89cd3f2c7adc78544d",uri="sip:[email protected]:5060",response="8025dd4c0573945db94c9565f983e875",algorithm=MD5
User-Agent: 3CXPhone for Windows 16.0.1.81
Content-Length: 20
chat support request
11/20/2019 9:36:07 AM - L:2834.2[Extn:634]: Terminating targets, reason: SIP ;cause=487 ;text="Request Cancelled"
11/20/2019 9:36:07 AM - Leg L:2834.2[Extn:634] is terminated: Cause: 487 Request Cancelled/INVITE from 192.168.1.34:5060
11/20/2019 9:36:07 AM - Call(C:2834), Extn:634 on exit: DlgInfo(2834-2350/Terminated / R)
11/20/2019 9:36:07 AM - Call(C:2834), Extn:634 on entry: DlgInfo(2834-2350/Early / R)
11/20/2019 9:36:07 AM - Notify dialog-info: Extn:634: sip:[email protected]:5060, Call(C:2834)
11/20/2019 9:36:07 AM - L:2834.2[Extn:634] got Terminated Recv 487/INVITE from 192.168.1.34:5060 tid=fb369b30f0358047 Call-ID=dRU_d6pGujM_H5gwfIG4Sg..:
SIP/2.0 487 Request Cancelled
So.... you are using *9 to page a particular extension... set to set paging? If so, I believe that the extension must have the Intercom feature enabled.
Hi Tim,
What function is *9 set to on your system? If set to paging then the extension from which you are dialing, will need the Right "Can intercom" enabled as @leejor mentioned. Without it the call should still work but it will be a normal call
13261
Wecare_ITA
