Solved A voice lists the incoming number and asks if i wishes to answer or not
SERENITIQUE
Hello there !
When a call is transferred to a mobile and is answered from the mobile, a voice lists the incoming number and asks if i wishes to answer or not. Do you know what option allow that ? I don't remeber to select that :rolleyes:
Check this option please:
I miss that...
Transfert is enabled with BLF
BLF is configured with "custom speed dial"
I use *30 in custom speed dial, it activate a statut (away)
Away "status forward external calls to" "my mobile"
"my mobile" is in Users/general/user information/mobile number
Then edit the Away status, this one also has rebound:
Resolved ! Great ! Thanks a lot
Reactions: JohnS_3CX
mazet
