Accidentally blacklisted my IP
Alphabetic
3CX MVP
Hello
I've blacklisted my IP from a 3CX and have admin console restrictions on.
How do I go about freeing myself?
3CX is on a VPS, I have full root access.
tia.
I'd login to the 3cx admin on my mobile, from a different ip/network and then whitelist the blocked ip.
Otherwise I think you're stuck until the block is released in 24h
Regards
Keith
Hi mate, you missed the part where I said I had console restriction on. but thanks nevertheless.
:rolleyes: Ah, yes missed the implications of that
I know it's VPS, but if there is a way to have some HTTPs access from any local IP, that should get you through.
Depending on urgency, since you have root, you should be able to do an SSH Tunnel/VPN if you are familiar with such things or the AIs decide to be helpful.
SSH tunneling
Perfect, im back in.
Reactions: KyriacosS_3CX
