Add IP Phone Extension Number Issue
sonnyh1
SOHO User
I am trying to add an IP Phone usind a specific ectension number, 7449, because of numbering system I use.
I can't find how to add the IP Phone using the dashboard, and the web client won't let me set a custom extension number.
If you access the web client with the System Owner extension, under the Admin section you can edit the extensions. In the extension 7449 you do not see the Ip Phone tab?
I ended up creating the extrension with the number I wanted using the "old" dashboard.
Then from the webclient admin created the router phone setup.
Hopefully they will add this function to the new webclient.
There are a lot fo things I do not like with the new v20 too
