After latest update Fanvil X5S periodically flashes Upgrade Finished!
Rick S
Running 16.0.910
X5S Firmware 1.12.2
Fanvil Template version - 89557 - Not Custom
I have deleted the phone from the extension, factory reset the phone, then added back to the extension. Problem persists.
I just saw an extra empty entry in the BLF fields that shouldn't have been there, so I deleted that and reprovisioned. Since it's periodic I don't know if that has fixed the issue, but seems weird in any case.
Any ideas?
Thanks,
Rick Stout
@Rick S and @David Forster
I have been observing some models that I setup in our test environment and it appears David is right.
Fanvil just displays the pop up message from time to time rather than suppressing it. It does not cause any issues, but I can understand it can be considered a minor annoyance by some. They have some settings for the pop ups, you can check this one if you want but I have not personally tested it myself.
12831
Reactions: David Forster
Thanks John, I'll give that a go and update this thread on if this solves the issue.
Regards, David.
Reactions: JohnS_3CX
So interestingly updating that tick box hasn't suppressed the message (but I didn't do a reboot after updating setting). I've now rebooted, so lets see that happens in 24 hours time.
Just updating this thread. A reboot hasn't resolved the issues re the Fanvil 'upgrade' message. I've also upgraded firmware on an X6 to the latest 3CX approved firmware and can confirm the same behaviour is now experienced on these handsets as well. I'm guessing this is something for 3cx to feedback to Fanvil to resolve in their next release. Current work around is to reboot your phones outside of normal hours, thus no one will observe the issue at subsequent times each day afterwards.
Thank you for the update. We can report this to Fanvil but since this is not a bug or a functioning problem it would be better if you as a user report this directly to them.
Thanks Yiannis, Yes no problem I will reach out to my contact at Fanvil, however I'm surprised you don't consider it a bug worth reporting to them. It's an issue that wasn't present in previous firmware versions and is a negative user experience for your customers using Fanvil (i.e. supported) handsets with 3cx.
Do not get me wrong, i will put a note down so can mention this to Fanvil but since this is not affecting the phones functionality we cannot report this as a bug. But if coming from multiple directions it has more chances of getting changed.
Agreed, thanks Yiannis.
Have their been any fixes for these two issues. The "Upgrade Finished" and the freezing issue?
As I had to return a customers x5s's as they had the issues and now on my 3cx pbx i'm getting both issues on the x6.
On the X5s the 'random freezing' and 'freezing on tranfer' seems to be fixed in the newest release (1.12.4).
The 'upgrade finished message flashing' still seems to be present. (To be fair, in hotdesking this isn't just a visual annoyance; while the message is on screen, it also says 'dial peer' in the background which will change to the correct hotdesking-number again after the 'upgrade finished' message has been closed. Whether its called a bug or not, it wasnt present in version 1.10.8 and its breaking stuff :D )
Hi Iccs,
I've reported it to Fanvil (via our UK distributor), any news via you comms with them @YiannisH_3CX ?
I agree it's causing some confusion with customers.
(we have only experienced the 'upgrading' not the freezing issue).
Dave.
Thanks for the info David! Would be nice if everything would be smooth again.
Just a bit of additional wondering:
That file was uploaded at 2019-10-31 tho.....
When browsing a bit at the Fanvil download directories. I noticed an upload of an engineering version 17.0 instead of 16.19 as well, uploaded at 2019-11-09. Also note that both are all in the Engineering directory instead of the Release directory.
You can always test these firmwares to see on 1 or 2 devices if the issue seems to be fixed, but in this stage, I'm not rolling them out into a production environment.
Interesting.
It's a useful resource, but like you say it's in the 'engineering' directory, not sure if this is their term for 'beta'. As you say, worth testing on a couple of non production handsets, but at least it gives an idea what's to come in the official release.
There have been 2 updates to Fanvil phones that I know of - our X5S phones are now at 1.12.5 as of this morning and I am still periodically getting the 'upgrade finished' message. It does not affect functionality, but if the last few updates were supposed to include a fix for this, it apparently is still not fixed.
Im assuming this is the case for a few Fanvil models as im getting "Upgrade complete" on the 4XU running FW 1.0.2
I too am having the same issue. 25 Fanvil X5S phones and running the latest 1.12.5, and for the last 2 or 3 FW upgrades, the users are complaining of their phones flashing "Upgrade Finished" across the screens.
Re-provisioned and Rebooted all the phones & 3CX server, didn't help.
3K8iMGWviZ
