Android Client showing that PBX is too old
fabiancrmaddon
I installed the Android Client and since I provisioned it using the mail I get the following message:
"We have detected an old and unsupported version of 3CX Phone System. This client will not run correctly with this version and will stop working all together on 1/1/2018. Please contact your administrator to upgrade 3cx to v15.5."
I checked my 3cx PBX and it tells me it´s up to date with version 15.5.10244.4. I also checked the app version, it´s 15.5.303.
I don´t really understand why I get this message, is there anyone else experiencing this or someone who has a solution ?
Best regards,
Fabian
Hello @fabiancrmaddon
Have you changed the User agent name of the PBX from the custom parameters? You can check by navigating to Settings / Parameters and search for USERAGENTSTRING. The value should be empty.
I have checked this and the USERAGENTSTRING has an empty value field, we didn´t change anything in there.
Best regards,
Fabian Zimbalev
@fabiancrmaddon
Please check to see if extension's Authentication ID contains a quote or double quote - if yes, change it, then reprovision the client and see if it works.
Hope it helps
vali
i've had this happen over a couple of updates on the android client. my fix was to go to the app manager and force stop the app. it worked after that
I checked the Authentication ID on the 3cx using the webinterface and on the client in the config but it does not contain any quotes, it´s pure digits like "124".
Also, I tried to force-quit the app but this did not change anything.
Does someone have any other ideas ?
@fabiancrmaddon
Please try to provision with the same extension another 3CX client (Windows, iOS, MAC) to see if you get the same error - and let us know.
we´ve got this extension running on a 3cx Phone for Windows without any problems.
I could eventually try iOS if needed.
Best regards,
Fabian
Mahlon
