automatic return of transfered call
Mahesha
Hi everyone,
is it possible to achieve that when you transfer inbound call to some extension (someone call main number at reception and you transfer that call to someone),if that extension doesnt answer, that call automatically return to you (reception)?
Hmmm...
If I'm not mistaken that functionality is enabled on asterisk 1.8 (Elastix 2.2) when you do a transfer
thx- for answering, do you have some more hints where to search for that functionality?
If I'm not mistake, it is enabled by default, you may try installing a test server to try it.
tnx again I will try it
Are you able to transfer call to an agent who is logged into the same queue using agent console ?? If yes, can you please help we are just going crazy
thnks
DejanMDS
