AWS lightsail with Custom FQDN SSL installation
KrisPbx
Hi All,
We have done 3CXExpress installation from backup. As we using custom FQDN now we need to install SSL. Can you advise on how to do that? Thanks
Hi Kris,
You will have to grab your certificates from the old installation and install them on the new machine, because the backup will not take care of custom certificates. The restoration will only generate temporary certificates just to get the system up and running.
If you want to install your custom certs, log in to the machine via SSH, and replace the existing ones with your own
Look at these paths here:
/var/lib/3cxpbx/Instance1/Bin/Cert/
/var/lib/3cxpbx/Bin/nginx/conf/Instance1/
Wecare_ITA
