Azure out-of-box unable to make any calls
Fischerit
I'm new to 3CX but I would think simple extension to extension would work. This is a new Azure deployment.
This is the error the Activity Log shows
Code:
12/01/2020 4:31:39 PM - Exception: ParseException ../../rutil/ParseBuffer.hxx:230, Parse failed unexpected eof in context:
2201
@ ../../rutil/ParseBuffer.hxx:230
How did you setup the Azure Instance with 3CX?
The only way you can really deploy anything on Azure. Selected the 3CX image from the marketplace.
Ok I was able to over come a list of issues. I think the last part is configuring the SIP Trunk correctly. The provider has sent me instructions for FreePBX system. Wireshark shows auth issue so I think the outbound parameters need to be setup. Its currently sending Call to <sip:fromuser@HostIP:0> I need it set to <fromuser:password@HostIP/fromuser>
So you need to either use a supported provider or ask this provider how to configure for 3CX.
hughesdouglas
