Blacklisting User Repeatedly
jasontype40
Platinum Partner
Intermediate Cert.
I have a user that keeps having their PC's IP blacklisted. It happens at least once a week. I have tried uninstalling the application, wiping all files out, and reinstalling. I have also tried reprovisioning their softphone. The user can't have a static IP so I need to figure out what is causing the blacklist.
What is the reason in the event log that blacklists the user?
You should have an entry in your event log showing something similar to the screenshot below.
The reason is "3CX Clients / Softphones blocked - 3CX API Component"
Can you clarify if the user is using Web client, Desktop App, Mobile App, 3CX Phone for windows v16?
They are using 3CX Phone for Windows v16
For a trial period ask the user to use the Desktop App to see if the 3CX Phone for Windows is causing the issue.
TVV40
