blind transfer v20
oscartraxx
Hello, I updated from v18 to v20, and now the blind transfer does not work.
Hi there.
Maybe you can describe your issue in more detail.
Are you using 3CX applications or physical phones?
Thanks for answering, I have the problem with physical Cisco 525g phones, I cannot transfer calls blindly, it tells me transfer error, in v18 it worked perfectly, when I updated to v20 it stopped working
Those devices are EOL and no longer, which means you have to manually configure them, and is not something we could test for you and advise.
Ensure your firmware is at least, something that is mentioned here
Hello, good afternoon, they are already configured and it works perfectly for me, but I couldn't do the transfer blindly, as I said before, in v18 it worked perfectly, but when I updated v20 it no longer works, it tells me an error, I don't believe May it be a problem with the physical phones, because they are in the same configuration that they had in the v18 version, I think it is a problem with the v20 switchboard that there is some problem that this option is not added.
Could you help me please.
I have more than 3000 extensions running, and what I am not going to do is change all the Cisco Spa 525g and Cisco 504g devices that worked on v18, change them because v20 is no longer officially recommended, please I need help to make this option work .
thank you
They were never recommended. Those were EOL a long time ago.
3CX doesn't recommended keeping old phones either. Usually you would've changed them all to supported models in a certain period of time.
We can't advise anything here and support you with those phones.
The above message is incorrect. I you go back an look at older versions of the software the were listed with a fully provisioned template out of the box for 3cx in the original versions that I purchased many years ago. In fact 888 recommended them. And your suggestion is that he just throw away 3000 phones. Not very business friendly.
Reactions: moniputerPBX
@telecommunicatio You don't need to throw them, find the way to configure them manually.
I'm the same issue with SNOM M300 and M25 handset, the DECT firmware is 530 - 10.
This issue impact only DETC to DECT call transfer, form 3cx windows app to DECT works fine.
thanks
Simone
Hi Simone.
So in your case, any transfer (blind and attended) between DECT does not work?
And what exactly you are facing?
Hi Oleg,
I did some tests so:
1 - blind transfert from DECT doesn't work, it seems the call remained linked to the 1st attendant.
2 - attended transfer works fine but when the the attendant click to transfert the DECT phone ask a second question to confirm the transfer.
Moreover I found a word around for M300 -M25 DECT or 3CX client v16 registration issue if you reset password on 3CX v20.
You need to add window 3CX app and provision on 3CX, on 3CX admin console click on 3dots related to user extension 3CX App for Windows on the menu select open → config and copy the AuthID and AuthPass from the file and copy them into M300 Extensions and Handset the turn on the DECT handset.
you will find the below into the file
<AuthID>xxxxxxxxxx</AuthID>
<AuthPass>xxxxxxxxxxx</AuthPass>
Hope this will be helpful for you
Simone
Thats the same what a reprovisioning does...
Reprovision item menu is grayed on SNOM M300 extension.
Carlos - EC Mates
