Solved bridged pbx presence
jakthree
3CX 15.5.56602.6 standard annual
I have setup a bridge between two 3CX PBX at site-1 (master) and site-2 (slave) using tunnel port 5090. The bridge shows connected (green dot). Site-1 extensions are four digit 1xxx. Site-2 are four digit 2xxx. Outbound rules are in place and I can intercom between sites.
During bridge setup, site-1 and site-2 bridge presence is set 'publish - DEFAULT group'.
9599
I understand that receiving presence of 'selected extensions' is part of PRO license.
9600
At 23:30 in the web tutorial is said 'each remote system which is bridged to the local pbx will be shown in the presence screens of the 3cx client and web client'.
The Site-1 windows web client does not show Site-2 presence tab.
The Site-2 windows web client does not show Site-1 presence tab.
Does this mean that web client remote presence tab is only shown in the PRO version?
Thank you,
I understand better now.
Thank you for your quick answers.
You only need PRO to see remote presence. If you have PRO on one and and STD on the other PRO can see the presence on STD but not the other way around.
That answers my question.
Thank you
Rich Hopkins
