Caal forwarding and DND
lubon
I'm trying to forward exteran calls to an external number.
When I do this wile in status 'away' it works as expected.
When I configure this on the same extension exactly the same in the 'Do not disturb' mode I get a message that there is no voice mail configured for this extension.
Is this a bug, or do I overlook something?
Best regards,
Luc
Hi, I wonder if you have the same configuring the forwarding with other extensions or is it a specific extension?
if you configure the forwarding from the 3cx app on smartphone do you have any error?
I did some more testing, it is happening on only 1 extension.
The user is system owner, so recreating it might make things complicated.
Any other suggestions?
Luc
this user has enabled the voice mail?
did you try configuring the forwarding rule from the 3cx app on smartphone and also from the pbx management console?
This user has not enabled voice mail. It doesn't change the behaviour wether voice mail is enabled or not (apart from the error message)
I tried to configure it as the user in the 3cx windows app and as admin on the console.
Since this is a Hosted by 3CX installation, please kindly open a technical support ticket with us so we can gather the logs and help you in this inconvenient.
mazet
