Call Journaling test fails in CRM Integration application
hoth
I currently have the following XML file, which is set up to do call journaling and do a look up on a contact based on their number and email address.
XML:
<?xml version="1.0"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="Debug-3CX" Version="1" SupportsEmojis="true">
  <Number Prefix="AsIs" MaxLength="[MaxLength]" />
  <Connection MaxConcurrentRequests="2" />
  <Parameters>
    <Parameter Name="UserName" Type="String" Parent="General Configuration" Editor="String" Title="Username:" />
    <Parameter Name="Password" Type="Password" Parent="General Configuration" Editor="String" Title="Password:" />
    <Parameter Name="ReportCallEnabled" Type="Boolean" Editor="String" Title="Enable Call Journaling" Default="True" />
    <Parameter Name="Subject" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Call Subject:" Default="3CX PhoneSystem Call" />
    <Parameter Name="InboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Inbound Call:" Default="[DateTime]: Answered incoming call from [Number] to [Agent] ([Duration])" />
    <Parameter Name="MissedCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Missed Call:" Default="[DateTime]: Missed call from [Number] to [Agent]" />
    <Parameter Name="OutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Answered Outbound Call:" Default="[DateTime]: Answered outgoing call from [Agent] to [Number] ([Duration])" />
    <Parameter Name="NotAnsweredOutboundCallText" Type="String" Parent="ReportCallEnabled" Editor="String" Title="Unanswered Outbound Call:" Default="[DateTime]: Unanswered outgoing call from [Agent] to [Number]" />
  </Parameters>
  <Authentication Type="Basic">
    <Value>[UserName]:[Password]</Value>
  </Authentication>
  <Scenarios>
    <Scenario Id="ReportCall" Type="REST" EntityId="Contacts" EntityOrder="[LookupOrder]">
      <Request SkipIf="[IIf([ReportCallEnabled]!=True||[EntityId]==&quot;&quot;,True,[IIf([CallType]!=Inbound,True,False)])]" Url="https://5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" Message="" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Value Key="webhookEvent" Passes="1" Type="String">suppdesk</Value>
          <Object Key="call">
            <Value Key="reference" Passes="1" Type="String">001234</Value>
            <Value Key="folderno" Passes="1" Type="String">1</Value>
            <Value Key="email" Passes="1" Type="Integer">[AgentEmail]</Value>
            <Value Key="phone" Passes="1" Type="Integer">[CallNumber]</Value>
            <Value Key="status" Passes="1" Type="String">open</Value>
            <Value Key="subject" Passes="2" Type="Integer">[Subject]</Value>
            <Value Key="description" Passes="1" Type="String">test desc</Value>
          </Object>
        </PostValues>
      </Request>
      <Variables />
      <Outputs Next="ReportCallMissed" AllowEmpty="false" />
    </Scenario>
    <Scenario Id="ReportCallMissed" Type="REST">
      <Request SkipIf="[IIf([ReportCallEnabled]!=True||[EntityId]==&quot;&quot;,True,[IIf([CallType]!=Missed,True,False)])]" Url="https://login:password@5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="call">
          </Object>
        </PostValues>
      </Request>
      <Variables />
      <Outputs Next="ReportCallOutbound" AllowEmpty="true" />
    </Scenario>
    <Scenario Id="ReportCallOutbound" Type="REST">
      <Request SkipIf="[IIf([ReportCallEnabled]!=True||[EntityId]==&quot;&quot;,True,[IIf([CallType]!=Outbound,True,False)])]" Url="https://login:password@5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="call">
          </Object>
        </PostValues>
      </Request>
      <Variables />
      <Outputs Next="ReportCallNotanswered" AllowEmpty="true" />
    </Scenario>
    <Scenario Id="ReportCallNotanswered" Type="REST">
      <Request SkipIf="[IIf([ReportCallEnabled]!=True||[EntityId]==&quot;&quot;,True,[IIf([CallType]!=Notanswered,True,False)])]" Url="https://login:password@5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="call">
          </Object>
        </PostValues>
      </Request>
      <Variables />
      <Outputs AllowEmpty="false" />
    </Scenario>
  </Scenarios>
</Crm>
I have set up values in "Parameter Values" for "Call Journaling" and have also got "ReportCallEnabled" set to True. Now when I run a test by clicking on "Call Journaling" after right clicking on "Parameter Values" I get the following exception,
System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at CrmIntegration.ScenarioProcessorBase.CreateJsonFromPostValues(RequestItem requestItem, IValueManager customManager)
at CrmIntegration.ScenarioProcessorBase.ProcessRequest(ScenarioRequest request, IValueManager customManager, HttpClient client, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.Execute(ProtocolScenario scenario, CancellationToken token)
at CrmIntegration.CrmProcessor.ExecuteScenarioByName(String scenarioName, IEnumerable`1 parameters, Boolean useNoAuthProvider, CancellationToken token)
at CrmIntegration.CrmProcessor.ExecuteScenarioWithRetries(String scenarioId, Dictionary`2 parameters, CancellationToken token)
at CrmIntegration.CrmProcessor.ReportCall(CallEndedEvent callEndedEvent, CancellationToken token)
Now the values set for "Call Journaling" under "Parameter Values" is as follows,
Have I missed something obviously wrong with this? I have no idea where I have gone wrong so would appreciate any help on this please.
The ReportCall scenario shouldn't have EntityType and EntityOrder attributes.
Also, it's [Number] and not [CallNumber].
I have removed the "EntityId" (I assume you meant this and not "EntityType") and "EntityOrder" from the "Scenario" tag and have replaced all "[CallNumber]" with "[Number]". In doing this would I also need to amend the "SkipIf" condition on the "Request" tab by removing "||[EntityId]==&quot;&quot;"?
You don't need to modify the request portion. Only the scenario.
Reactions: edossantos
FYI
Removing the condition has now resulted in no error message but I now get a blank response,
This is currently what the "ReportCall" scenario looks like now,
XML:
<Scenario Id="ReportCall" Type="REST">
      <Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Inbound,True,False)])]" Url="https://login:password@5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" Message="" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="call">
            <Value Key="phone" Passes="1" Type="Integer">[Number]</Value>
          </Object>
        </PostValues>
      </Request>
      <Variables />
    </Scenario>
FYI
XML:
        <PostValues>
          <Object Key="call">
          </Object>
        </PostValues>
      </Request>
      <Variables />
    </Scenario>
I'm not sure you can use login:password in the URL. However, you'll wanna check your API side and see if requests are coming in.
The ReportCall scenario will not return any response. It's just to report a call, i.e. log the call in your CRM. You need another scenario to do the contact lookup, and that one will return the contact details.
So the CRM application is actually one I have locally running in debug mode in Visual Studio. The problem I have is that when there is no exception thrown, which suggests that maybe the POST was run by 3CX, there is no incoming request in my CRM application.I have a breakpoint, which I would expect to get hit, which doesn't. As a test I have now removed the "Skip if" condition but it now returns the "System.FormatException: Input string was not in a correct format" exception like before.
What @ConceptsWeb mentioned about sending the user & password in the URL will not work in this case. Did you change that? That's something that the browser interprets as basic authentication, but 3CX will not do that. In this case you need to specify the actual URL and the credentials as headers.
Yes, so I have removed the "login:password@" bit from the URL but have still had no luck. This is currently what I have,
XML:
      <Request SkipIf="[IIf([ReportCallEnabled]!=True,True,[IIf([CallType]!=Inbound,True,False)])]" Url="https://5623-2a01-4b00-e208-dd00-980f-da75-1287-c64d.ngrok-free.app?A=HttpApiSuppdeskWebHook" MessagePasses="0" Message="" RequestContentType="application/json" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="call">
          </Object>
        </PostValues>
      </Request>
      <Variables />
    </Scenario>
With or without any headers for the credentials, I would expect my CRM application to at least receive the incoming request from 3CX, which is what is not happening for some odd reason.
Regarding this:
[Subject] is a parameter that you have defined, and the default value is "3CX PhoneSystem Call", which is a string, and not an integer. That will cause the error you described previously:
If you're not seeing that error, that means that the scenario is not being executed, probably skipped. That will depend on the values you set in the Properties window when you debug this from the CRM Tool.
Reactions: hoth
Regarding this:
Thank you so much! This along with email was set to the incorrect type! Having corrected this I'am now receiving requests in my CRM application!
arming
