Solved Caller ID and PhoneBook Matching
Vadood
We are using 3CX 15.5.0
I wonder if we can put caller ID on incoming calls based on matching the number with a list of names in a phonebook.
We have a limited set of phone numbers calling us and we want to see the callers name on the phone when there is an incoming call.
thanks
The 3CX phone book will attach a name, if a number match is found, in the same way a mobile phone, or set directory does. Not sure how you intend to "put caller ID on incoming calls". The call either has Caller ID (number and perhaps a name), or it doesn't.
You may need to provide more detail on what you are trying to achieve.
Hello @Vadood
Add the numbers in the 3CX phone book. If the incoming number is matched to a contact then you will see the contacts name on the phones display.
Yes thank you both Leejer and Yiannish, I was able to find out how to do this
Glad to see the issue has been resolved and thank you for the update
apbGroup
