Solved Calling directly from 3cx Webclient
shiftcontrol
I am able to use my USB headset and call directly from our Webclient (without using an IP phone or the 3cx Desktop Client)
To do this, I type a number in https://<<our address>>/webclient/
However when I try to use 3cx click to call to take me to this address
https://<<our address>>/webclient/#/call?phone=0411111111
It brings up a dialpad and prefills the number however when I click dial I get a "Phone Not Connected" red error.
Is there any other way to dial directly from the webclient? I want to have staff hotdesking and not needing to have physical phones/3cx webclients to be provisioned each time.
Hello @shiftcontrol
On your webclient, what is the way to call configured next to the Status bar ?
12500
It's set to 3cx web client
12512
I can type a number into the "Enter Name or Number" field but when I try to use the url below to prefill a number, the dialpad shows "No Phone Connected"
What is surprising is that this is also using the webclient to dial. I would have thought these two ways of dialling would be the same.
Just following up on this, does anyone have any workaround?
Hi @shiftcontrol
As a test:
  1. Make a new extension, without adding a phone.
  2. Connect to it via webclient
  3. Now click on a number to dial
Does this work?
(I assume you are using the latest Chrome)
Hi @shiftcontrol
As a test:
Does this work?
Hi JohnS
Thanks for your reply. I have the latest version of chrome and tried your suggestion.
Google Chrome is up to date
Version 77.0.3865.90 (Official Build) (64-bit)
  1. I can still call using the input https://192.168.36.236/webclient/#/settings
  2. However this doesn't work https://192.168.36.236/webclient/#/call?phone=0411111111
It still says "Phone Not Connected". I would have thought that this would use the same method to call as option 1 above.
In a private message send me:
  1. full screenshot please (including the address bar) of a normal call that works
  2. full screenshot please (including the address bar) of a click2call that fails
  3. what is your HTTPS port? if you don't know check Settings>Parameters> CALLUS_LINK_EXT_SEC and tell me this value
Hi @JohnS_3CX I have just replied in private. Thanks for your help so far.
This happens in the webclient on V15.5. Upgrade your PBX to V16U3 and you should be ok.
PS: Also note your FQDN points to a private IP - this might cause you problems in other areas
Hi @JohnS_3CX thanks for your update on this. We are looking to update to 3cx v16U3 so this is great news. Appreciate you helping on this.
No worries, glad to help. If you have any questions or need help before upgrading to V16 you can start a new thread and ask anything you need.
aurorasigntrtechitnet
