Can not add Twilio SIP trunk in 3CX Admin panel
robertv
New User
When I go to the 3CX panel and click on "Add SIP Trunk" and choose worldwide or the USA it does not show me the option of Twilio in "Select Provider in your Country".
How I can add Twilio option there?
You are Hosted on 3CX, and those don't support IP Based trunks like Twilio.
Reactions: [email protected]
Among all three which one I should use and how.
If you have to ask, Hosted by 3CX is your best bet, you just have to go with a provider that is supported (registration-based SIP trunks). If you have to use Twilio then the next best option would be self-host in your cloud.
Do note that if you already spun up a 3CX hosted instance you'll have to have them turn it off before you spin up a self-hosted or they will conflict.
Senergia
