Can't Provision a X3G
davidCTI
Having trouble provisioning new phones.
Fanvil X3G, this phone is not listed in the add phone list. have tried SG U as well but no luck
Have done the X6U ok so I know the procedure is right.
turned off the external blocking in options, is latest firmware.
Any thoughts
thanks
David
Thanks.
Managed to get provisioning to work, X3 and X3S both do same job. Phone shows it has the extension from the setup. I get a dial tone but can't dial out. Both line buttons are flashing
Does not report as green still has a red light. Other phones 6 are green?
thanks
If you use plug and play provisioning, it should automatically detect the right template for you.
Just make sure the firmware is updated. See guide below and reprovision it from scratch, in a factory default state https://www.3cx.com/sip-phones/fanvil-x3-x5/
[email protected].
