Cant Record Calls Not Free?
MySaures
Feature available only in 3CX PBX Professional and 3CX PBX Enterprise Edition
but on here https://www.3cx.com/ordering/pricing/ shows call record is on standard and my LIC is shows
Standard Annual 16.0.0.982
last night it was working i could record calls then this morning tills me an update to the system happen and now i cant record calls yet the plan shows i can
The edition comparison is for the current version, v15.5 and even then I think is out of date as of the most recent service pack with regards to call recording. You are running the alpha version so all bets are off.
so i have to switch back to 15.5?.... and turn off auto updates?
if so is there away to roll back to first install or... have to start from scratch
Rolling back is not supported but you can try it. The supported path is to uninstall and restore from a v15.5 backup and make sure auto-updates doesn't include the beta updates.
Hello @MySaures
As mentioned you need to go back to V15.5 as V16 is still on Alpha. You will need to use a V15.5 backup to do so as V16 backups are not compatible with V15.5/ Also please note that Alpha and Beta releases will not apply if auto-updates are on so it is weird that your system updated. Make sure that no one else has access to the system and that can trigger the update.
Reactions: craigreilly
ccocala.org
