CFD for 3CX Hosted
alanao
https://www.3cx.com/ordering/pricing/hosted-info/ says CFD on Hosted is available only for ENT licenses can anyone confirm the difference of CFD on Pro and ENT? I am currently on PRO and have access to Call Processing Script but no option to upload the txt file for my dialer numbers. Will this provide that?
You will not have access to the 3CX server when using a Hosted by 3CX instance.
You can try SIP Caller instead, which uses a totally different approach and doesn't require you to upload anything to the server.
Just a idea: upload your whole text as call script. It will not compile, no problem.
You can access the content with
C#:
string codetext = (PhoneSystem.Root.GetRoutePoints().Where( x => x.Number.Equals("name_or_number_of_the_call_script")).FirstOrDefault()).ScriptCode;
You can also add it as a 3CX parameter and avoid the compilation error, or configure the CFD app to get the information from a web service.
However, all this will require a lot of work, and the result will be poor. Better going with a proven solution :-)
Hi alanao, just a footnote on your query-thread. If you need 3cx hosted in an environment where you have full admin access to the VM/host. (a) such a setup is possibly to setup yourself - in theory - but if this is outside your comfort zone / not something you wish to consider trying, then (b) another easy option is to work with someone who can host your 3cx instance for you / set it up for your requirements / to meet this functional need (ie, you need SSH access to the 3cx instance to upload/insert files via WinSCP for example?)
If this sounds correct, and possibly useful, please let me know. I have a number of SMB clients I'm hosting 3cx instances for and it is ~very doable as a 'modest size project'. I can optionally help (or not) with things once the instance is setup, as per your needs/preference.
No pressure, just FYI.
Tim
DejanMDS
