Solved Change all codecs in extensions
BartoszB
Titanium Partner
Intermediate Cert.
What can I change all codecs in extensions for PCMA and PCMU? When I select all extensions and set only PCMA and PCMU the changes will not be saved. Is there any other way to change the codecs?
For the clients it can be done centrally since the introduction of V18 from Settings >> Codecs
If you are on V16 you have to upgrade to get this feature.
Hello JohnS_3CX
Okay, I know in v18 they fixed it. I have v16.
I did this, connected to the 3CX API, and replaced the codecs on all extensions
Resolved
Reactions: JohnS_3CX
GP Concepts
