Solved change If I do not answer calls within:
mohamed hamed
how to change forwarding rules ->internal calls -> If I do not answer calls within (time) for all extensions
What you can do is actually select all extensions by clicking the first checkbox in the "Extensions" section:
Then, just click on "Edit", go to "Forwarding Rules >> Available" and set the ring time for internal calls to the value you want. Click on OK and now the change should apply to all extensions.
Reactions: mohamed hamed
Thank you , it's working
Glad I could help!
Please feel free to start a new thread should you need additional assistance or information.
devo.it
