Chat Logs
JPrentice
I am looking to grant permission to some of my users to view the chat logs for audit purposes. They are all using the DeskTop app.
I am the system owner, and can see the chat logs in the reporting section of the admin section in the app, however, I cannot seem to assign permission to other user.
The only way I appear to be able to make the reporting option available, is to make then the system owner of the Chat Group
The option to "Monitor (Has access to reports, chat logs, call logs & recordings)" appears to have no effect at all.
I am running version 18, update 9
Does any one have any ideas what I am missing please ?
I could get the same result by exporting to a csv, but then I dont get the chat transcript, just a list of the chats. A feature upgrade perhaps?
Thanks in advance
Hi there.
Since you are in V18, you can get the users to log in to the 3CX management console using their extension, and then you will allow the user to do that under the Users >> Ringhts >> Allow access to 3CX Management Console
Thanks OlegR_3CX - that seems to work. Odd that it doesn't work in the app, but at least it is a solution
Thanks for your help
Yes, this will have other information.
Also, if the chat go via the Queue, you can be admin of the Queue and then see the chats there too directly from the user settings :
Reactions: JPrentice
EMMEPICASA
