CNAME DID Logic Trunk
leva
Hi everyone, I try show the name company when I call from 3CX but not working, My provider of sip trunk is did logic and they applied the cname display configuration so What else do I need to make it work?
What does not working mean? The receiving party is getting the correct number and no name/unknown? Or the correct number and the wrong name? You can check your using something like https://calleridtest.com/. Twilio will also do lookups. The country you are in matters as well as different countries handle caller ID differently.
Reactions: YiannisH_3CX
The receiving party receives the correct number on their caller ID but should receive the company name. If I do a look up test at https://calleridtest.com with the number of my trunk sip if it gives me the name of the company, the call is made within the same city
Have you tried testing to a number of destinations (ILEC landlines). Some providers do not do (pay for) name look-ups. If your provider is sending the name, then in heopry, id shuld go through. If they have simply added your company name to a database to match your number(s), then it will still rely on the destination to "get" the name.
BIT Incorporated
