{"code": 400, "message": "redirect uri mismatch."}
greychain
Gold Partner
You should contact the developer of this integration as it is a third-party not only on 3CX but Odoo as well.
That's why our integration doesn't use any third-party modules.
Unfortunately I dont have the skill level or time to write an XML-RPC to Rest API gateway as that would be the only way I could avoid using 3rd party apps.
DM me. We can probably help you. We already have that gateway/proxy built.
Yeah but I thought the idea was to avoid using 3rd party app
I am stuck with using the provided API, I'll have to wait for either 3CX to reply or Synconics.
Do you provide the full code base?
Yes. With the XML template. It uses the XMLRPC API but through the proxy.
EMMEPICASA
