Solved Configure custom speed dial (BLF) for multiple extensions
boulianne
Hey guys,
Would it be possible to configure a custom speed dial BLF on more than one extension at a time ?
Yes, just multi-select the extensions and click Edit.
Reactions: boulianne
Hold the shift key on the extensions page and just click as many extensions as is required basically.
Thanks guys,
I will give that a try !
It works ! Thanks guys :)
GP Concepts
