- Joined
- Mar 12, 2021
- Messages
- 11
- Reaction score
- 2
Hello everyone,
I have a VTiger 7.4 opensource CRM setup. When I tried to integrate the CRM with my 3CX, it shows that it is not supported. I tried to install this VTiger API module but when I try manual authentication it shows me a 500 HTTP error: https://github.com/sardoj/VTRestfulAPI
As I've been reading in integrating unsupported CRMs, it shows that the CRM server needs to have an API, yet i can't find anything on how to add one properly that supports calls as well.
Anyone else had this problem or similar? Any way to fix the problem or integrate the CRM through any other mean, like some other API integration?
Before anything else, I wanna apologize for not being a pro in this aspect so I need a bit more instructions than the average user perhaps to understand where I'm going wrong!
Regards.
Regards.
