DIDForSale provider and Fax
DexDeadly
I know the fax server does not work in the free version. However the demo key is supposed to unlock all the features with only 2 simultaneous calls. Does this not include the 3CX faxing? Please let me know. I keep trying to configure it but I feel I might just be wasting time at this point.
Re: Fax Server
I have all the ports forwarded and the firewall checker comes back 100% clean. What in my firewall would cause this? I'm running a IPCop installation behind my Verizon router. My IPCop is DMZed in my verizon router and then all the ports are forwarded to my server. Everything else seems to work. What am I missing?
Re: Fax Server
Get wireshark and do a capture. It is the only reliable way to determine how and if the packets are being routed/received correctly.
The log is indicating that no RTP packets are being received. You can use the telephony flow to see how the call is being negotiated and then see what IP addresses are being used.
I have seen where the firewall only kept the port open for a little bit and then shut it down.
I have seen where the RTP packets got routed to an IP that was not the same as the one needed (maybe a second NIC in the server)
I have seen where the firewall perceived the constant stream as a DOS attack (my guess)
The bottom line is that while the logs are very helpful, they don't show all the activity, they only show the activity that is centric to the IP address of the 3CX server.
Re: Fax Server
I've installed Wireshark. I've never used this before. I just tried to send a fax using faxzero service. I have wireshark running. How tdo I just sort out the information needed to look into this. Also what about the other error thats in my system eventlog?
The description for Event ID '1073741824' in Source '3CXFAXSrv' cannot be found. The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them. The following information is part of the event:'Service procedure completed with code 0'
I appreciate all the help and plan on purchasing this software once I get this up and running.
Re: Fax Server
Ok, let's focus on the basics to begin with.
You are using a Sip trunking provider? If not, then what? You have a DID dedicated as a inbound fax number and the DID is being routed to the system fax extension 888 by rule. The sip provider has conditioned the line for t.38 and this has been confirmed. I question this as you seemingly have reported a couple of different providers. Please indicate the sip provider name.
You have tested the 3cx send mail capability and have received messages.
You have opened and forwarded the appropriate ports on you router according to the blog, port 10000-10009 udp and pointed them to the server?
You have stopped and restarted the fax server to be certain it is running and system extension 888 currently shows registered?
Did you modify any of the fax template files? If so, how.
What version of 3cx?
I know that many of these are redundant to prior question/answers, I am just trying to get a new base established.
Re: Fax Server
Ok so here is what I got.
I have DIDForSale as my DID provider.
3CX Version 11 SP3 running
Windows 2003 Enterprise Server SP2 completely up to date w/ 2GB RAM
I have verified with DIDForSale that the line is setup for t.38.
The emails are correctly sending and I have the following ports forwarded to my box
5000, 5060, 5090, 9000-9049 & 10000-10009 all forwarded to my Server.
When I stop and restart the Fax server is when I get this error:
When clicking on the System extensions I do see 888 registered but idle.
Re: Fax Server
Very Weird....
...but the Log says that the Answer (from provider) was
DexDeadly said:
26-Jan-2013 20:08:22.750 Offer is rejected on Leg L:2.1[Line:10000<<+18009806858];
OnOfferRejected Recv 488/INVITE from 209.216.15.70:5060 tid=fd15c526b2025878 [email protected]:
SIP/2.0 488 Not Acceptable Here
Via: SIP/2.0/UDP 10.1.2.10:5060;received=72.94.24.236;branch=z9hG4bK-d8754z-fd15c526b2025878-1---d8754z-;rport=5060
Record-Route: <sip:209.216.15.70;lr;ftag=3568237698-887444>
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>;tag=3568237698-887444
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Call-Info: <sip:64.125.111.10>;method="NOTIFY;Event=telephone-event;Duration=1000"
Content-Length: 0
and it was for the Offer
DexDeadly said:
26-Jan-2013 20:08:21.979 L:2.1[Line:10000<<+18009806858] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=264bc37cb65a3a14 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-264bc37cb65a3a14-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
Content-Length: 298
v=0
o=3cxPS 411058569216 200974270466 IN IP4 72.94.24.236
s=3cxPS Audio call
c=IN IP4 72.94.24.236
t=0 0
m=image 9004 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:10500
a=T38FaxMaxDatagram:1500
a=T38FaxUdpEC:t38UDPRedundancy
Re: Fax Server
What does that mean? You think there not sending it correctly or is the system interpreting it wrong?
Re: Fax Server
Well the first issue is that the log file is 4 days old, so am uncertain that what happened then is representative of what might happen now. You did not indicate if you edited any of the fax templates. There was a blog requirement for earlier 3CX versions that required some additional preparation for faxing. Did you edit the templates?
What edition of 3CX? Now that we know it is v11, would like to know if free, demo, 4 call, etc.
What SY saw is that the log is indicating that an attempt was made to negotiate a protocol between 3CX and your provider. However, it appears that the provider's system rejected the attempt. Presumably, the attempt was to get to T.38. This goes hand-in-hand with the lack of packets that I noticed.
Re: Fax Server
I apologize. I am using DEMO mode so that I can test all of the enterprise features and the Fax being a big one. I just tried sending another fax through faxzero.com website and here is the log of the call.
0-Jan-2013 14:42:36.523 [MS105000] C:6.2: No RTP packets were received:remoteAddr=127.0.0.1:10002,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7020
30-Jan-2013 14:42:36.523 MSLogReports
30-Jan-2013 14:42:35.187 L:6.2[Fax] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=11C4DBA6 Call-ID=YWI4OGUxNTk2MzAyZjk3NTliNjhjZGRlZjUzYzE1YjA.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK11C4DBA6
To: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=b5269732
From: <sip:[email protected]:5060;user=fax>;tag=72-2B21
Call-ID: YWI4OGUxNTk2MzAyZjk3NTliNjhjZGRlZjUzYzE1YjA.
CSeq: 8 BYE
Content-Length: 0
30-Jan-2013 14:42:35.187 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=b5269732 to <sip:[email protected]:5060;user=fax>;tag=72-2B21
30-Jan-2013 14:42:35.085 L:6.2[Fax]: Terminating targets, reason:
30-Jan-2013 14:42:35.085 Leg L:6.2[Fax] is terminated: Cause: BYE from PBX
30-Jan-2013 14:42:35.084 Terminated from <sip:[email protected]:5060;user=fax>;tag=72-2B21 to "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=b5269732; reason: LocalBye
30-Jan-2013 14:42:35.084 L:6.2[Fax] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=4a49796a122fc063 Call-ID=YWI4OGUxNTk2MzAyZjk3NTliNjhjZGRlZjUzYzE1YjA.:
BYE sip:[email protected]:5100 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-4a49796a122fc063-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]:5060;user=fax>;tag=72-2B21
From: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=b5269732
CSeq: 2 BYE
Content-Length: 0
30-Jan-2013 14:42:35.084 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=b5269732 to <sip:[email protected]:5060;user=fax>;tag=72-2B21
30-Jan-2013 14:42:35.084 L:6.2[Fax] Sending: OnSendResp Send 488/INVITE from 0.0.0.0:0 tid=C52127F1 Call-ID=YWI4OGUxNTk2MzAyZjk3NTliNjhjZGRlZjUzYzE1YjA.:
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bKC52127F1
CSeq: 7 INVITE
Content-Length: 0
30-Jan-2013 14:42:35.084 [CM503008]: Call(C:6): Call is terminated
30-Jan-2013 14:42:35.084 L:6.2[Fax]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
30-Jan-2013 14:42:35.081 Blocking refers for the Call(C:6)
30-Jan-2013 14:42:35.081 Call(C:6) is terminated
30-Jan-2013 14:42:35.081 L:6.1[Line:10000<<+18009806858]: Terminating targets, reason:
30-Jan-2013 14:42:35.081 Leg L:6.1[Line:10000<<+18009806858] is terminated: Cause: BYE from PBX
30-Jan-2013 14:42:35.077 Terminated from <sip:[email protected]>;tag=3568563779-599799 to <sip:[email protected]:5060>;tag=a13cd814; reason: LocalBye
30-Jan-2013 14:42:35.076 L:6.1[Line:10000<<+18009806858] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=1e76e7793a096641 [email protected]:
BYE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-1e76e7793a096641-1---d8754z-;rport
Max-Forwards: 70
Route: <sip:209.216.2.211;lr;ftag=3568563779-599799>
To: <sip:[email protected]>;tag=3568563779-599799
CSeq: 3 BYE
Reason: SIP;description="Application Rejected Sdp(usually no common codec)"
Content-Length: 0
30-Jan-2013 14:42:35.076 SendMsg from <sip:[email protected]:5060>;tag=a13cd814 to <sip:[email protected]>;tag=3568563779-599799
30-Jan-2013 14:42:35.076 Offer is rejected on Leg L:6.1[Line:10000<<+18009806858];
OnOfferRejected Recv 488/INVITE from 209.216.2.211:5060 tid=7e1d6a7447014807 [email protected]:
Via: SIP/2.0/UDP 10.1.2.10:5060;received=72.94.24.236;branch=z9hG4bK-d8754z-7e1d6a7447014807-1---d8754z-;rport=5060
Record-Route: <sip:209.216.2.211;lr;ftag=3568563779-599799>
CSeq: 2 INVITE
Content-Length: 0
30-Jan-2013 14:42:34.619 L:6.1[Line:10000<<+18009806858] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=5026620bfa1c6508 [email protected]:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-5026620bfa1c6508-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 INVITE
Supported: replaces
Content-Length: 298
v=0
o=3cxPS 524019564544 226442084354 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=image 9022 udptl t38
a=T38FaxVersion:0
30-Jan-2013 14:42:34.619 SendMsg from <sip:[email protected]:5060>;tag=a13cd814 to <sip:[email protected]>;tag=3568563779-599799
30-Jan-2013 14:42:34.616 Providing SDP for L:6.1[Line:10000<<+18009806858]
30-Jan-2013 14:42:34.616 Direct SDP re-negotiation due to Fax re-INVITE
30-Jan-2013 14:42:34.616 Reneg. from L:6.2[Fax], offer
30-Jan-2013 14:42:34.616 Leg L:6.2[Fax] raised event RecvdRemoteSdp
30-Jan-2013 14:42:34.616 Remote SDP is set for leg L:6.2[Fax]
30-Jan-2013 14:42:34.616 Offer SDP arrived on Leg L:6.2[Fax];
OnOffer Recv Req INVITE from 127.0.0.1:5100 tid=C52127F1 Call-ID=YWI4OGUxNTk2MzAyZjk3NTliNjhjZGRlZjUzYzE1YjA.:
Max-Forwards: 70
Contact: <sip:[email protected]:5100>
CSeq: 7 INVITE
Allow: INVITE, BYE, ACK, OPTIONS, CANCEL
User-Agent: Netbricks-Sip-T.38IAF/2.01 (PRODUCT ID:5, 05 Jul 2007)
Content-Length: 284
v=0
o=3CXFaxServer 2890844526 890844528 IN IP4 netbricks.com
s=-
c=IN IP4 127.0.0.1
t=0 0
m=image 10000 udptl t38
a=T38FaxVersion:0
30-Jan-2013 14:42:33.603 Session 12733 of leg L:6.1[Line:10000<<+18009806858] is confirmed
30-Jan-2013 14:42:33.603 L:6.1[Line:10000<<+18009806858] got Confirmed Recv Req ACK from 209.216.2.211:5060 tid=a50b.8bfdc114.2 [email protected]:
ACK sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 209.216.2.211;branch=z9hG4bKa50b.8bfdc114.2
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK99680672cdd9b273783cfc171092a5a7
Max-Forwards: 66
Record-Route: <sip:209.216.2.211;lr=on;ftag=3568563779-599799>
To: <sip:[email protected]:5060>;tag=a13cd814
From: <sip:[email protected]>;tag=3568563779-599799
CSeq: 1 ACK
Content-Length: 0
P-hint: rr-enforced
30-Jan-2013 14:42:33.603 ConnCfmd from <sip:[email protected]>;tag=3568563779-599799 to <sip:[email protected]:5060>;tag=a13cd814
30-Jan-2013 14:42:33.121 [CM503007]: Call(C:6): Fax:888 has joined, contact <sip:[email protected]:5100>
30-Jan-2013 14:42:33.117 [CM503007]: Call(C:6): Line:10000<<+18009806858 has joined, contact <sip:[email protected]@209.216.2.211:5060>
30-Jan-2013 14:42:33.117 Session 12733 of leg L:6.1[Line:10000<<+18009806858] is connected
30-Jan-2013 14:42:33.117 L:6.1[Line:10000<<+18009806858] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=a50b.8bfdc114.0 [email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 209.216.2.211;branch=z9hG4bKa50b.8bfdc114.0
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK535218284b8f3ef285f3ee20e199b701
CSeq: 1 INVITE
Supported: replaces
User-Agent: 3CXPhoneSystem 11.0.28392.820 (27565)
Content-Length: 224
v=0
o=3cxPS 524019564544 226442084353 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=audio 9020 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 14:42:33.117 Connected(UAS) from <sip:[email protected]>;tag=3568563779-599799 to <sip:[email protected]:5060>;tag=a13cd814
30-Jan-2013 14:42:33.117 L:6.1[Line:10000<<+18009806858] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=a50b.8bfdc114.0 [email protected]:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
i did not make any changes to the fax templates. I simply installed 3CX and then put in a demo key. i have not made any changes to the system or its files in any fashion.
Re: Fax Server
Can you check and see if you just got a fax cover page. I sent one to what I think is the number and got a success indication.
Re: Fax Server
I didn't get any emails. Did you fax it to 12152789726 ? That is the number I have forwarded. Here is the log of what looks like your fax.
30-Jan-2013 20:18:50.672 [MS105000] C:7.2: No RTP packets were received:remoteAddr=127.0.0.1:10002,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7024
30-Jan-2013 20:18:50.672 MSLogReports
30-Jan-2013 20:18:49.475 L:7.2[Fax] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=204123C4 Call-ID=N2Y3Nzg3YjFlYmIyZGI2ODNjZjc4ZGUxMzY4NmVlOWQ.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK204123C4
To: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=c6136135
From: <sip:[email protected]:5060;user=fax>;tag=72-8024
Call-ID: N2Y3Nzg3YjFlYmIyZGI2ODNjZjc4ZGUxMzY4NmVlOWQ.
CSeq: 9 BYE
Content-Length: 0
30-Jan-2013 20:18:49.475 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=c6136135 to <sip:[email protected]:5060;user=fax>;tag=72-8024
30-Jan-2013 20:18:49.375 L:7.2[Fax]: Terminating targets, reason:
30-Jan-2013 20:18:49.375 Leg L:7.2[Fax] is terminated: Cause: BYE from PBX
30-Jan-2013 20:18:49.375 Terminated from <sip:[email protected]:5060;user=fax>;tag=72-8024 to "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=c6136135; reason: LocalBye
30-Jan-2013 20:18:49.374 L:7.2[Fax] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=1426d203081e8f18 Call-ID=N2Y3Nzg3YjFlYmIyZGI2ODNjZjc4ZGUxMzY4NmVlOWQ.:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-1426d203081e8f18-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]:5060;user=fax>;tag=72-8024
From: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=c6136135
CSeq: 2 BYE
Content-Length: 0
30-Jan-2013 20:18:49.374 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=c6136135 to <sip:[email protected]:5060;user=fax>;tag=72-8024
30-Jan-2013 20:18:49.374 L:7.2[Fax] Sending: OnSendResp Send 488/INVITE from 0.0.0.0:0 tid=1C61CAA1 Call-ID=N2Y3Nzg3YjFlYmIyZGI2ODNjZjc4ZGUxMzY4NmVlOWQ.:
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK1C61CAA1
CSeq: 8 INVITE
Content-Length: 0
30-Jan-2013 20:18:49.374 [CM503008]: Call(C:7): Call is terminated
30-Jan-2013 20:18:49.374 L:7.2[Fax]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
30-Jan-2013 20:18:49.371 Blocking refers for the Call(C:7)
30-Jan-2013 20:18:49.371 Call(C:7) is terminated
30-Jan-2013 20:18:49.370 L:7.1[Line:10000<<+19564254764]: Terminating targets, reason:
30-Jan-2013 20:18:49.370 Leg L:7.1[Line:10000<<+19564254764] is terminated: Cause: BYE from PBX
30-Jan-2013 20:18:49.365 Terminated from <sip:[email protected]>;tag=3568583955-3489 to <sip:[email protected]:5060>;tag=9478ec2b; reason: LocalBye
30-Jan-2013 20:18:49.365 L:7.1[Line:10000<<+19564254764] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=6b05dd2e040da250 [email protected]:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-6b05dd2e040da250-1---d8754z-;rport
Max-Forwards: 70
Route: <sip:209.216.15.70;lr;ftag=3568583955-3489>
To: <sip:[email protected]>;tag=3568583955-3489
CSeq: 3 BYE
Content-Length: 0
30-Jan-2013 20:18:49.365 SendMsg from <sip:[email protected]:5060>;tag=9478ec2b to <sip:[email protected]>;tag=3568583955-3489
30-Jan-2013 20:18:49.365 Offer is rejected on Leg L:7.1[Line:10000<<+19564254764];
OnOfferRejected Recv 488/INVITE from 209.216.15.70:5060 tid=a2198d64356ae83d [email protected]:
Via: SIP/2.0/UDP 10.1.2.10:5060;received=72.94.24.236;branch=z9hG4bK-d8754z-a2198d64356ae83d-1---d8754z-;rport=5060
Record-Route: <sip:209.216.15.70;lr;ftag=3568583955-3489>
CSeq: 2 INVITE
Content-Length: 0
30-Jan-2013 20:18:49.047 L:7.1[Line:10000<<+19564254764] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=3507a833b33c4162 [email protected]:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-3507a833b33c4162-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 INVITE
Supported: replaces
Content-Length: 298
v=0
o=3cxPS 315680096256 336819388418 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=image 9026 udptl t38
a=T38FaxVersion:0
30-Jan-2013 20:18:49.046 SendMsg from <sip:[email protected]:5060>;tag=9478ec2b to <sip:[email protected]>;tag=3568583955-3489
30-Jan-2013 20:18:49.043 Providing SDP for L:7.1[Line:10000<<+19564254764]
30-Jan-2013 20:18:49.043 Direct SDP re-negotiation due to Fax re-INVITE
30-Jan-2013 20:18:49.043 Reneg. from L:7.2[Fax], offer
30-Jan-2013 20:18:49.043 Leg L:7.2[Fax] raised event RecvdRemoteSdp
30-Jan-2013 20:18:49.043 Remote SDP is set for leg L:7.2[Fax]
30-Jan-2013 20:18:49.043 Offer SDP arrived on Leg L:7.2[Fax];
OnOffer Recv Req INVITE from 127.0.0.1:5100 tid=1C61CAA1 Call-ID=N2Y3Nzg3YjFlYmIyZGI2ODNjZjc4ZGUxMzY4NmVlOWQ.:
Max-Forwards: 70
CSeq: 8 INVITE
Content-Length: 284
v=0
s=-
c=IN IP4 127.0.0.1
t=0 0
a=T38FaxVersion:0
30-Jan-2013 20:18:48.450 Session 17145 of leg L:7.1[Line:10000<<+19564254764] is confirmed
30-Jan-2013 20:18:48.450 L:7.1[Line:10000<<+19564254764] got Confirmed Recv Req ACK from 209.216.15.70:5060 tid=ac94.90046672.2 [email protected]:
Via: SIP/2.0/UDP 209.216.15.70;branch=z9hG4bKac94.90046672.2
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bKf74846fe07cc2244c6470c4f8228b99e
Max-Forwards: 66
Record-Route: <sip:209.216.15.70;lr=on;ftag=3568583955-3489>
To: <sip:[email protected]:5060>;tag=9478ec2b
CSeq: 1 ACK
Content-Length: 0
P-hint: rr-enforced
30-Jan-2013 20:18:48.450 ConnCfmd from <sip:[email protected]>;tag=3568583955-3489 to <sip:[email protected]:5060>;tag=9478ec2b
30-Jan-2013 20:18:48.186 L:7.1[Line:10000<<+19564254764] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=ac94.90046672.0 [email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 209.216.15.70;branch=z9hG4bKac94.90046672.0
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK9cc293940329660989944b6282af2137
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
v=0
o=3cxPS 315680096256 336819388417 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=audio 9024 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 20:18:48.186 SendMsg from <sip:[email protected]:5060>;tag=9478ec2b to <sip:[email protected]>;tag=3568583955-3489
30-Jan-2013 20:18:47.571 [CM503007]: Call(C:7): Fax:888 has joined, contact <sip:[email protected]:5100>
30-Jan-2013 20:18:47.566 [CM503007]: Call(C:7): Line:10000<<+19564254764 has joined, contact <sip:[email protected]@209.216.2.211:5060>
30-Jan-2013 20:18:47.565 Session 17145 of leg L:7.1[Line:10000<<+19564254764] is connected
30-Jan-2013 20:18:47.565 L:7.1[Line:10000<<+19564254764] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=ac94.90046672.0 [email protected]:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 20:18:47.565 Connected(UAS) from <sip:[email protected]>;tag=3568583955-3489 to <sip:[email protected]:5060>;tag=9478ec2b
30-Jan-2013 20:18:47.565 L:7.1[Line:10000<<+19564254764] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=ac94.90046672.0 [email protected]:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 20:18:47.565 SendMsg from <sip:[email protected]:5060>;tag=9478ec2b to <sip:[email protected]>;tag=3568583955-3489
Re: Fax Server
NO, I used the 800 number. When I tried the 215 number I get nothing but a fast busy. So, it seems that you have employed some form of fax forwarding service.
Have you tried to dial the number (215) your self and if so, what do you get?
My impression is that there should be a DID provided from a provider that allows direct access to 3CX and then routed accordingly to the server at 888.
Re: Fax Server
All I have is a DID that is from DIDForSale and setup in my box with an inbound rule to send to the email of the extension. If I call the number I am getting disconnected right away.
Re: Fax Server
I am getting completely confused.
You use DID4Sale as a provider. How many DID numbers do you subscribe to?
You should have one DID that is, by rule, indicated as send fax to email of extension 888.
I just tried again with a fax. Please check your logs. I just get a fast busy, so am uncertain that I even reach 3CX.
Re: Fax Server
I have 4 DIDs from DIDForSale. The server is hosted here at my house. I have that one DID set to just send to the email of the fax extension 888
Re: Fax Server
I have 4 DIDs from DIDForSale. The server is hosted here at my house. I have that one DID set to just send to the email of the fax extension 888. Here is the log.
30-Jan-2013 21:48:12.333 [MS105000] C:15.2: No RTP packets were received:remoteAddr=127.0.0.1:10002,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7054
30-Jan-2013 21:48:12.333 MSLogReports
30-Jan-2013 21:48:11.155 L:15.2[Fax] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=F171B9F1 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bKF171B9F1
To: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d
From: <sip:[email protected]:5060;user=fax>;tag=72-CAC6
Call-ID: ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.
CSeq: 16 BYE
Content-Length: 0
30-Jan-2013 21:48:11.155 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d to <sip:[email protected]:5060;user=fax>;tag=72-CAC6
30-Jan-2013 21:48:11.054 L:15.2[Fax]: Terminating targets, reason:
30-Jan-2013 21:48:11.053 Leg L:15.2[Fax] is terminated: Cause: BYE from PBX
30-Jan-2013 21:48:11.053 Terminated from <sip:[email protected]:5060;user=fax>;tag=72-CAC6 to "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d; reason: LocalBye
30-Jan-2013 21:48:11.053 L:15.2[Fax] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=2511b24d7c0f0226 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-2511b24d7c0f0226-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]:5060;user=fax>;tag=72-CAC6
From: "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d
CSeq: 2 BYE
Content-Length: 0
30-Jan-2013 21:48:11.053 SendMsg from "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d to <sip:[email protected]:5060;user=fax>;tag=72-CAC6
30-Jan-2013 21:48:11.053 L:15.2[Fax] Sending: OnSendResp Send 488/INVITE from 0.0.0.0:0 tid=021793F1 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK021793F1
CSeq: 15 INVITE
Content-Length: 0
30-Jan-2013 21:48:11.052 [CM503008]: Call(C:15): Call is terminated
30-Jan-2013 21:48:11.052 L:15.2[Fax]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
30-Jan-2013 21:48:11.049 Blocking refers for the Call(C:15)
30-Jan-2013 21:48:11.049 Call(C:15) is terminated
30-Jan-2013 21:48:11.049 L:15.1[Line:10000<<+19564254764]: Terminating targets, reason:
30-Jan-2013 21:48:11.048 Leg L:15.1[Line:10000<<+19564254764] is terminated: Cause: BYE from PBX
30-Jan-2013 21:48:11.044 Terminated from <sip:[email protected]>;tag=3568589317-947067 to <sip:[email protected]:5060>;tag=0a38546a; reason: LocalBye
30-Jan-2013 21:48:11.044 L:15.1[Line:10000<<+19564254764] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=08333f04a5683c2f [email protected]:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-08333f04a5683c2f-1---d8754z-;rport
Max-Forwards: 70
Route: <sip:209.216.15.70;lr;ftag=3568589317-947067>
To: <sip:[email protected]>;tag=3568589317-947067
CSeq: 3 BYE
Content-Length: 0
30-Jan-2013 21:48:11.044 SendMsg from <sip:[email protected]:5060>;tag=0a38546a to <sip:[email protected]>;tag=3568589317-947067
30-Jan-2013 21:48:11.043 Offer is rejected on Leg L:15.1[Line:10000<<+19564254764];
OnOfferRejected Recv 488/INVITE from 209.216.15.70:5060 tid=89263274a2787158 [email protected]:
Via: SIP/2.0/UDP 10.1.2.10:5060;received=72.94.24.236;branch=z9hG4bK-d8754z-89263274a2787158-1---d8754z-;rport=5060
Record-Route: <sip:209.216.15.70;lr;ftag=3568589317-947067>
CSeq: 2 INVITE
Content-Length: 0
30-Jan-2013 21:48:10.712 L:15.1[Line:10000<<+19564254764] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=d638a5474031583d [email protected]:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-d638a5474031583d-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 INVITE
Supported: replaces
Content-Length: 298
v=0
o=3cxPS 542256398336 271052701698 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=image 9006 udptl t38
a=T38FaxVersion:0
30-Jan-2013 21:48:10.712 SendMsg from <sip:[email protected]:5060>;tag=0a38546a to <sip:[email protected]>;tag=3568589317-947067
30-Jan-2013 21:48:10.708 Providing SDP for L:15.1[Line:10000<<+19564254764]
30-Jan-2013 21:48:10.708 Direct SDP re-negotiation due to Fax re-INVITE
30-Jan-2013 21:48:10.708 Reneg. from L:15.2[Fax], offer
30-Jan-2013 21:48:10.708 Leg L:15.2[Fax] raised event RecvdRemoteSdp
30-Jan-2013 21:48:10.708 Remote SDP is set for leg L:15.2[Fax]
30-Jan-2013 21:48:10.708 Offer SDP arrived on Leg L:15.2[Fax];
OnOffer Recv Req INVITE from 127.0.0.1:5100 tid=021793F1 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
Max-Forwards: 70
CSeq: 15 INVITE
Content-Length: 284
v=0
s=-
c=IN IP4 127.0.0.1
t=0 0
a=T38FaxVersion:0
30-Jan-2013 21:48:09.533 Session 18325 of leg L:15.1[Line:10000<<+19564254764] is confirmed
30-Jan-2013 21:48:09.533 L:15.1[Line:10000<<+19564254764] got Confirmed Recv Req ACK from 209.216.15.70:5060 tid=aa6.75470c76.2 [email protected]:
Via: SIP/2.0/UDP 209.216.15.70;branch=z9hG4bKaa6.75470c76.2
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK400a46a296b4d07f6c3d82c3129d3c1b
Max-Forwards: 66
Record-Route: <sip:209.216.15.70;lr=on;ftag=3568589317-947067>
To: <sip:[email protected]:5060>;tag=0a38546a
From: <sip:[email protected]>;tag=3568589317-947067
CSeq: 1 ACK
Content-Length: 0
P-hint: rr-enforced
30-Jan-2013 21:48:09.533 ConnCfmd from <sip:[email protected]>;tag=3568589317-947067 to <sip:[email protected]:5060>;tag=0a38546a
30-Jan-2013 21:48:09.221 [CM503007]: Call(C:15): Fax:888 has joined, contact <sip:[email protected]:5100>
30-Jan-2013 21:48:09.215 [CM503007]: Call(C:15): Line:10000<<+19564254764 has joined, contact <sip:[email protected]@209.216.2.211:5060>
30-Jan-2013 21:48:09.215 Session 18325 of leg L:15.1[Line:10000<<+19564254764] is connected
30-Jan-2013 21:48:09.215 L:15.1[Line:10000<<+19564254764] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=aa6.75470c76.0 [email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 209.216.15.70;branch=z9hG4bKaa6.75470c76.0
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK79bd9847311e69c320f96d4c521f6ada
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
v=0
o=3cxPS 542256398336 271052701697 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=audio 9004 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 21:48:09.215 Connected(UAS) from <sip:[email protected]>;tag=3568589317-947067 to <sip:[email protected]:5060>;tag=0a38546a
30-Jan-2013 21:48:09.215 L:15.1[Line:10000<<+19564254764] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=aa6.75470c76.0 [email protected]:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 224
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:101 0-15
a=sendrecv
30-Jan-2013 21:48:09.215 SendMsg from <sip:[email protected]:5060>;tag=0a38546a to <sip:[email protected]>;tag=3568589317-947067
30-Jan-2013 21:48:09.212 ~Target=
30-Jan-2013 21:48:09.212 L:15.1[Line:10000<<+19564254764]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
30-Jan-2013 21:48:09.211 ~Route=Dev:sip:[email protected]:5100;user=phone
30-Jan-2013 21:48:09.211 L:15.2[Fax] has joined to L:15.1[Line:10000<<+19564254764]
30-Jan-2013 21:48:09.211 Session 18330 of leg L:15.2[Fax] is connected
30-Jan-2013 21:48:09.211 L:15.2[Fax] got Connected.UAC Recv 200/INVITE from 127.0.0.1:5100 tid=681e7b41dc674927 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5060;received=127.0.0.1;rport=5060;branch=z9hG4bK-d8754z-681e7b41dc674927-1---d8754z-
CSeq: 1 INVITE
Server: Netbricks-Sip-T.38IAF/2.01 (PRODUCT ID:5, 05 Jul 2007)
Content-Length: 166
v=0
o=3CXFaxServer 2890844526 890844527 IN IP4 netbricks.com
s=-
c=IN IP4 127.0.0.1
t=0 0
m=audio 10002 RTP/AVP 0
a=ptime:20
a=sendrecv
30-Jan-2013 21:48:09.211 Connected(UAC) from <sip:[email protected]:5060;user=fax>;tag=72-CAC6 to "4Twelve-Solutions Fax:"<sip:[email protected]:5060;nf=e>;tag=4f1a0d3d
30-Jan-2013 21:48:09.211 Remote SDP is set for leg L:15.2[Fax]
30-Jan-2013 21:48:09.211 Answer SDP arrived on Leg L:15.2[Fax];
OnAnswer Recv 200/INVITE from 127.0.0.1:5100 tid=681e7b41dc674927 Call-ID=ZDlkYWRiYWQ4ZTZhMzU5MzMzYWJiZjU2N2Y0YzM5MmY.:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 166
v=0
s=-
c=IN IP4 127.0.0.1
t=0 0
a=ptime:20
a=sendrecv
30-Jan-2013 21:48:09.211 [CM503002]: Call(C:15): Alerting Fax:888 by contact <sip:[email protected]:5100>
Re: Fax Server
Yes, that is me.
Will definitely need a wireshark capture. I am using nothing more than a fax machine connected to an analog POTS line. Sorry but I am done for the eve. I will try and help more tomorrow.
Re: Fax Server
How exactly should I run the wireshark capture. Is there anything specific that I should be running in it or just hit run and then try to find it in the logs? I've never used Wireshark actually. I did run and try to find RTP packets and it looks like it came in with no loss but again I'm not sure if I was using it correctly.
Re: Fax Server
Before we get to wireshark, there have been quite a few changes -
When you first started the thread, you indicated that you were running the application on a server, but did not mention which OS. You then reported that the server failed and that you had installed on WIN7. You subsequently reported that you re-setup your server and that you were then on Server 2008. In the message yesterday, responding to my back to basics, you then/now respond that the software is on Windows Server 2003 Enterprise SP2. What are we actually working with? Server 2003 is not supported for V11. Now then, this does not necessarily mean that it won't/does not work, just that issues might arise which may cause a problem and for which support to resolve may be non-existent. Again, I do not know that any of your issues are related, but by the same token it is always better to work with the approved objects (SIP providers, phones, gateways, etc.), so that the need to re-invent the wheel is not encountered.
So which OS and if 2003, can we get to an OS that is supported? Server 2008 or WIN 7 would be fine, but I encourage you to use the machine & OS that you intend to put into production should you ultimately elect to buy the software. I would not use 2003 as 3CX could come up with a service pack, new version or other future tidbit that really forces 2003 out the door. Why take the chance.
Finally, for the machine that we will continue with, make certain that the initial install and subsequent set-up and troubleshooting is limited to only one network interface card. If there are others, please disable them.
Re: Fax Server
Yes I have moved it between a few different machines trying to get this as of right now the server is installed on a Windows 2003 machine. If its not supported I must of missed that and its my fault. I do have the windows 7 machine setup still. Let me bring that back online. This machine has only 1 network card.
LachlanC
