Digit Receptionist, Multiple Extensions, 1 PSTN Line
harddrive41
I am currently having issues with my setup:
3CX 6.x
Linksys SPA 3102
1 POTs line
Right now I have 1 extension setup for test purposes. Everything is green, my extension and my PSTN line via the VoIP Gateway.
When I call in, it just rings and rings even though I have the PSTN line pointed to my softphone extension 2000 and it's up and registered.
I also can't call outbound? Not sure if I need to manually create all the rules?
I'm at a loss here.
After this is fixed, the plan is to create 5 extensions. 1 will be my current analog phone plugged into the FXS port. 2 will be softphones and 2 will be just vmail fowards from the Digital Receptionist. I lost on how to setup the physical analog phone as an extension? The rest I can figure out..but I have to figure out what's wrong with not taking calls at all and dialing outbound.
Any help would be great!
Mike..Ok..I setup everything the way you listed there. Im in the US BTW..NY to be exact. Here is the log for outbound from my softphone after I made the changes:
18:55:59.531 MediaServerReporting::RTPReceiver [MS105000] C:12.2: No RTP packets were received:remoteAddr=127.0.0.1:16398,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7036
18:55:59.531 Call::Terminate [CM503008]: Call(12): Call is terminated
18:55:27.875 CallLeg::onConfirmed Session 7276 of leg C:12.1 is confirmed
18:55:27.546 CallCtrl::onLegConnected [CM503007]: Call(12): Device joined: sip:[email protected]:5060
18:55:27.546 CallCtrl::onLegConnected [CM503007]: Call(12): Device joined: sip:[email protected]:5700;rinstance=625de2542962370d
18:55:27.546 MediaServerReporting::SetRemoteParty [MS210003] C:12.1:Answer provided. Connection(transcoding mode):192.168.0.103:7034(7035)
18:55:27.546 MediaServerReporting::SetRemoteParty [MS210001] C:12.2:Answer received. RTP connection: 127.0.0.1:16398(16399)
18:55:27.546 Line::printEndpointInfo [CM505002]: Gateway:[PSTN] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.7(GW)] Transport: [sip:192.168.0.103:5060]
18:55:27.546 CallLeg::setRemoteSdp Remote SDP is set for legC:12.2
18:55:27.546 CallCtrl::onAnsweredCall [CM503002]: Call(12): Alerting sip:[email protected]:5060
18:55:27.437 MediaServerReporting::SetRemoteParty [MS210002] C:12.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7036(7037)
18:55:27.421 CallCtrl::onSelectRouteReq [CM503004]: Call(12): Calling: PSTNline:7255835@(Ln.10000@PSTN)@[Dev:sip:[email protected]:5060]
18:55:27.421 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]:5060]
18:55:27.421 MediaServerReporting::SetRemoteParty [MS210000] C:12.1:Offer received. RTP connection: 192.168.0.113:42004(42005)
18:55:27.421 CallLeg::setRemoteSdp Remote SDP is set for legC:12.1
18:55:27.421 Extension::printEndpointInfo [CM505001]: Ext.2001: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 6.0.727.0] Transport: [sip:192.168.0.103:5060]
18:55:27.421 CallCtrl::onIncomingCall [CM503001]: Call(12): Incoming call from Ext.2001 to [sip:[email protected]:5060]
18:55:27.406 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.113:5700;branch=z9hG4bK-d8754z-6948e071a345fe22-1---d8754z-;rport=5700
Max-Forwards: 70
Contact: [sip:[email protected]:5700]
To: [sip:[email protected]:5060]
From: "3CXPhone"[sip:[email protected]:5060];tag=1b6d395f
Call-ID: MDdkYTZlNGIwMDhiYTE4MTYzMTA3NzdjNTZiMTQ3ZGI.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
Proxy-Authorization: Digest username="2001",realm="3CXPhoneSystem",nonce="12871439727:dc691ebe6916f07eeb309bdfaa9aa519",uri="sip:[email protected]:5060",response="41bb75b2dcc154a0e9ef2410a383732f",algorithm=MD5
Supported: replaces
User-Agent: 3CX Phone 6.0.727.0
Content-Length: 0
My question would be why it's referring to the loopback address in any of that (127.0.0.1), as that might be where you're getting the issue stem from.
Anyway, with the attached web-links attached you should find my setup. Beware, it's for a UK PSTN though, although I assume your 3102 would come preconfigured for US POTS (as most of these damn things do!)
http://www.pentangle.co.uk/spa3102-setup/spa3102-router-lan.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-router-wan.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-router-application.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-system.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-sip1.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-sip2.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-regional1.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-regional2.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-regional3.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-line1.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-pstnline1.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-pstnline2.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-pstnline3.jpg
http://www.pentangle.co.uk/spa3102-setup/spa3102-voice-pstnline4.jpg
Hope that helps.
Cheers,
Mike.
Mike,
I'm a bit confused I think. I should've told you how my Linksys SPA 3102 is setup on the network itself. I have Cable internet coming into the House. From that the network goes to a a Dlink 825 Router. The Digital phone comes out of the modem into the Line port on the SPA3102. I have the Lan port on the Linksys conntected to the Dlink Router but nothing connected on on the WAN port.
Questions:
1. Do I need to connect the WAN or Lan port or both if the Linksys SAP3102 is behind the Router?
2. I need to use LINE 1 (PSTN) provided by my internet provider as the inbound and outbound line?
It should connect to the wan port
and I explained ho do you now your wan ip
please read and set carefuly
It goes as per my post above ref: the internet port.
My SPA3102 is inside my firewall. The big problem is that the SPA3102 is designed to be a firewall of it's own.
In the UK, we can't (yet, due to BT's stupid monopoly) get ADSL lines without having a POTS line. Hence my setup is a POTS line, upon which broadband is enabled. The PSTN side of that POTS line goes into the Line port, and the broadband side goes into my Cisco 837 router. I use the Cisco as the default gateway (obviously), and as such the SPA3102 is within that NAT boundary when the LAN is plugged into it's Internet port. Confusing, I know, but that's the mode in which to use these things when they're so convinced they should be doing the firewalling for you instead of a proper router.
HTH
Mike.
Thank you both for all your help, galal and Mike. Everything is working great! Thanks again. Now on to setting up my attendant..etc. :lol:
You're welcome :)
Well..I think I spoke too soon. Here's what's going on now:
1. I can take inbound and make outbound calls on my softphone only if LINE 1 on the SPA 3102 is disabled. If I enable it, I can't call inbound or outbound from my softphone or my analog phone hooked up to the PHONE PORT on the Linksys SPA 3102. I get dial tone, but when I make a call from the Analog it dials then goes to busy on any outside line. When I point my inbound to my Analog ext, 2000, analog phone will not ring.
Any ideas? I verified the Line 1 port has the settings that galal wanted be to put in there.
I would assume it's something to do with a port conflict on 5060 between the two setups. Why do you need to keep that enabled? Just go 100% VoIP :)
(I use the Snom M3 at home with one of these and it works a treat)
I'm actually using PORT 5060 with Line 1 and 5061 with PSTN. I need to use the analog becuase I have no IP Phones as of yet, only two softphones. I would like to setup the digital attendant to give the caller a choice:
1- Analog phone setup as ext 2000 using Line 1
2-My softphone
3-my daughter's softphone
4- vmail for my cousin who is staying with us for a while
5-repeat the message.
I don't think you can use the same 3102 as a VoIP gateway AND an ATA at the same time?
Hmm...well..I bit the bullet and just ordered teh SNOM M3 from newegg. Should be here Friday. I'll let youknow how I make out.
Mike :lol:
If you follow then instructors
Just follow
You'll get analogue phone and pstn line
And your port settings correct
Just follow
I followed the instructions and still had those issues mentioned. What PORT should LINE 1 be? That's not in your config that you recommended? What SIP port should be on 3cx? The Gateway port and PSTN port I have are 5061 on 3cx and SPA3102.
The issues are, I could not receive inbound calls on the Analog PHone hooked to Line 1?
ports in spa3102
5060 for line1
5061 for pstn
poth must be enabled
ports in 3CX
5060 for extension
5061 for pstn gateway
Well my luck is just crap. galal..I had it setup like that and it didn't work..again..my analog extension would not ring.
Pentangle..I recevied the snom m3 and I can't get it to register to the gateway....i'm not sure what' going on.
Very frustrated. :cry:
If I'm in your place
I'll reinstall windows, 3CX and spa3102 from factory settings
try to use a pc with good specifications
The name's Mike :)
Have you checked whether you have the firewall enabled on the server? (if so, disable it).
The Snom M3 is a piece of cake to configure, so if you're having this sort of issue it sort of points towards something like a crappy firewall product being in the way.
Just a quick update..after working with SNOM it appears that some models are defective and can't get a DHCP address. They are aware of it and I am returning my phone for a replacement. I'll update this post when I get the new phone.
Thanks for everyone's help.
On another note, anyone using the SNOM's with the SNOM repeater? What kind of range are you getting?
Mike
Well, I received my second Snom M3 and still having issues trying to obtain DHCP address. Matt or Mike, can one of you guys help out here?
EMMEPICASA
