Remove their physical phone thenI'm trying to block CTI.
The "Call using <Physical Phone>" option that the users get in Web Client and apps.
Hi, if the physical phone needs to be used and you don't want that they use CTI within the 3cx apps, then they must be trained and learn that they don't have to change that parameter, there is not option to disable the CTI within the 3cx app, otherwise they will need to use only deskphones or the 3cx apps, not both.Of course removing the phone will make them unable to control (the non existant phone).
But that is bot an option.
Users should be able to call using their physical phone. But shouldn't be able to control the phone remotely.
This is what is meant by "disabling CTI".
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
