Dynamics365 integration - Error AADSTS50011
T2G
Hi, I'm testing out the integration of CRM - Dynamics365 to our 3CX. I followed the documentation here - https://www.3cx.com/docs/dynamics-crm-integration/
But I'm getting an error on the Authorization part of the process. I encountered the AADSTS50011 error which means
The redirect URI 'https://xxxxxx.3cx.asia:5001/api/oauth2crm' specified in the request does not match the redirect URIs configured for the application 'd59xxxxxxxxxxxxxxxxxxxxxx'. Make sure the redirect URI sent in the request matches one added to your application in the Azure portal.
This is my first time integrating a CRM to our 3CX, I would like to know where I can find or what's the correct Redirect URI, I just followed the documentation and I only replaced the sample url with our 3CX management console.
The Redirect URL is what you configure in the Azure Portal, as described in point 2.c in our guide. Please ensure that the Redirect URL prefix matches the URL you use to access the management console. If you're accessing it on port 5001 then use ":5001", otherwise remove the port. You can also show us the URL you use for your Management Console, and the one you configured in Azure.
EMMEPICASA
