Enterprise License 3CX dns Fqdn not resolving in 5 minutes
ECOM GROUP (Mauritius)
Before , the enterprise license was to a customer fqdn,
Now i have another installation on premise and the license on it was a Pro with 3cx fqdn
I have released the Enterprise license and upgrade the Pro license i just mentioned while keeping the Pro pbx 3cx's fqdn
Does the pro fqdn will automatically start resolving dns in 5 min instead of pro version 6 hours?
i cannot see any dns update even after hours.
i have change my on premise installation dns server to 8.8.8.8 4.4.44 and i have added same dns to my IPS provider router..
still fqdn is not resolving.
kindly help. thanks
Could it be more simple for you to host PBX in cloud with AWS, OVH, or GOOGLE have static IP, and no matter about having dynamic ip on location .
what do you thing about this?
i have already a cloud one, there are no issue with it, the only thing is my sip is locally hosted. each time ip change, i have to refresh sip reg manually then it work, other than that there is no issue in cloud.. ovh
have used this week OVH for an instance S1-8 , it's 2vcore, 8go ram and 40goHdd , static ip included , cost is 12.99€ /month
Are you located in Mauritius islands?
what do you mean you are your own sip provider?
Our telecom provide SIP line with Private IP, no sip account but IP Based only. via an eSBC Orange Livebox Business lBB 240
actually a nslookup point always on previous IP or is it up to date?
Sorry for this no idea what it implies and how this works, but are you obliged to use this SIP way , you can subscribe SIP trunks where you want no ?
when you explain all this it seem to me so easy to run a pbx with no pain, you are strong to continue with so many problems at all level. nothing helps you :(
There are only one SIP Trunk provider in Mauritius, and This is how they call it sip here.. outdated
other provider out of Mauritius are not available for you? or like IP it start at 1000$
OVH is also doing sip trunks but I don't know how many they are billing
Well , sorry for now , I don't see what more we can do, I'm out of new ideas. I wish you a pleasant night if it is now for you, i'm going to sleep .
If i had fresh ideas i will post
i was out. just came back. thanks. I need sip did for Mauritius which is not available from other provider outside mauritius.
good night
Thanks a lot for trying to help anyway
Reactions: AWS2P
3K8iMGWviZ
