Solved Error updating from 16.0.5.619 to 16.0.5.622
spaan
I'm trying to update from 16.0.5.619 to version 16.0.5.622, but it fails with the following message:
Reading package lists...
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
Does anyone know how to fix this issue so i can update?
I'm using the Debian ISO image.
That's usually when another APT process is running. Perhaps a crashed update.
Have you tried rebooting the system and attempting the update again?
Reactions: NickD_3CX
Hi @spaan,
Following up, are you still receiving this issue? Did you follow @Frederick Marcoux's advice and reboot then try again?
Hi @Frederick Marcoux & @VasilisV_3CX
I have just rebooted the system and it somewhat helped.
The error changed.
Now i have the following error:
Code:
Hit:1 http://downloads.3cx.com/downloads/debian stretch InRelease
Get:2 http://security.debian.org stretch/updates InRelease [53.0 kB]
Ign:3 http://httpredir.debian.org/debian stretch InRelease
Hit:4 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
Hit:5 http://httpredir.debian.org/debian stretch-updates InRelease
Hit:6 http://httpredir.debian.org/debian stretch Release
Ign:7 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch InRelease
Err:8 http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch Release
  404  Not Found [IP: 52.222.139.105 80]
Get:9 http://security.debian.org stretch/updates/non-free Sources [2,212 B]
Get:10 http://security.debian.org stretch/updates/main Sources [375 kB]
Get:11 http://security.debian.org stretch/updates/main amd64 Packages [722 kB]
Get:12 http://security.debian.org stretch/updates/main Translation-en [334 kB]
Get:13 http://security.debian.org stretch/updates/non-free amd64 Packages [5,772 B]
Get:14 http://security.debian.org stretch/updates/non-free Translation-en [15.7 kB]
E: The repository 'http://repo.saltstack.com/apt/debian/9/amd64/archive/2019.2.0 stretch Release' does no longer have a Release file.
But still can't update.
You will need 2 things here the first is to overcome the issue above and the next will be needed from sp6 to sp7.
For the salt stack repo issue, use this command:
Code:
wget -O - https://downloads.3cx.com/downloads/misc/debianpatches/9/16/0/5/20200619-os-update.sh | bash
Then try the update again, then once you update and need to go from sp 6 to sp7 use the following commands one line at a time:
Code:
apt update
wget http://security.debian.org/debian-security/pool/updates/main/o/openexr/libopenexr22_2.2.0-11+deb9u4_amd64.deb
apt install libilmbase12
apt install ./libopenexr22_2.2.0-11+deb9u4_amd64.deb
apt install libfreeimage3
apt install 3cxpbx=16.0.7.1078
Once updated to sp7 update to sp8 as normal.
Code:
Code:
apt update
We had to do this last week on a customer's system too. It does work if it's done properly.
Reactions: Charles_3CX
Code:
I have run the first command, and tried to update again. But i get the following error:
Code:
Ign:1 http://httpredir.debian.org/debian stretch InRelease
Hit:2 http://security.debian.org stretch/updates InRelease
Hit:3 http://httpredir.debian.org/debian stretch-updates InRelease
Hit:5 http://httpredir.debian.org/debian stretch Release
Hit:6 http://downloads.3cx.com/downloads/debian stretch InRelease
Hit:7 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
E: The method driver /usr/lib/apt/methods/https could not be found.
Should i just try to run the rest of the commands?
Never mind. Just run the apt update from the commandline and it provided the fix. Now trying to update further. I will report the result or any other errors.
Now running version 18.0.237.
So after some initial hickups everything updated from the GUI.
Thanks for the help!
You are welcome, glad this is now updated.
Rich Hopkins
