Solved Export List of Call Queues
LukeBurrows
I work for an MSP and we have our own 3CX instance. I am wondering if its possible to export a list of call queues and their members into a CSV file?
Kind Regards
Hi Luke,
Is this for a StartUP system or a dedicated one?
Hi Luke,
I can't post anywhere else so I had to post it here. Its self hosted but I cant post in the self hosted section.
Hi Luke,
You can run one of the Queue reports we have available, and it will list all the members of the queue. (ie. Queue Performance Overview)
Hi Luke,
That isnt quite what im looking for. I want to export a list of every call queue, with the memebers in each call queue in one report. Also is it possible to just export a list of call queues in a report? All from the admin panel using the admin account.
We do not have a function that does the exact thing your requested, however the method I suggested gets you close.
You can then manipulate the generated CSV file to your requirements:
Reactions: N_G
That actually worked per
You can then manipulate the file generated CSV to your requirements:
That actually worked perfectly. I just had to delete 4 collums.
Thank you :)
Reactions: JohnS_3CX
You're very welcome!
