Solved Extension Configuration - Disable the ability to exit the queue
morphey
I'm looking for a way to disable the "Queue" key from the 3cx Windows client:
in the extension settings there is not an option that disables the autonomy of managing the queue status of the end user.
is there a feature of this kind in the next releases?
Basically I'm looking for a way to inhibit a user's queue exit.
I also tried to leave it in queue and put the status to "Do Not Disturb" but it keeps ringing the phone if it gets a call in the queue.
Hi @VasilisV_3CX ,
Thanks for the report. I tried to search first but hadn't seen it.
I sincerely hope that an administrator function will be introduced to take away this possibility.
Thank you,
Reactions: VasilisV_3CX
Sure thing @morphey, feel free to upvote the idea and maybe save the link to check for updates. If you require anything else feel free to open a new thread.
