Solved Extension Presence issue over Bridge connection between two 3cx Sites
Dilip
Forum User
I have two 3cx server both servers are version 16.0.6 with pro license I have bridge two 3cx servers with master slave configuration
following the link :https://www.3cx.com/3cxacademy/videos/advanced/3cx-bridge-configuration/
But I cant see the presence of other site ext from one site I am able to call between the two sites.
Also there are no extension groups,I am using default group on both sites.
I have added the FQDN:5001 with port no on the presence information tab to retrieve information on both master and Slave trunk
But still not able to view the Presence information of other site extension
Added Snippet of the Configuration from both 3cx sites
have you checked group rights options ?
and the first one is
Hi aws2p
Yes it is checked in both 3cx sites groups still not able to see the presence
Where are you looking for presence? (ie. on a phone or in the Webclient)
In the webclient I would advise you to check Settings > Personalize > Group Presence and see if both Groups appear there firstly.
Hi JohnS_3CX
I am not able to see the remote site extension presence from the 3cx webex client and 3cx app But able to make call between two sites
I have added the FQDN:5001 with port no on the presence information tab to retrieve information on both master and Slave trunk But still not able to view the Presence information of other site extension
Can you confirm if both systems are currently on a valid Pro license?
JohnS_3CX
Yes Both 3cx system are on Pro-edition with version 16.0.619
Can each system reach the other on port 5001?
JohnS_3CX
How to test and confirm it Please tell me the steps
Well for example if PBX1 is installed in Office1, try from that network to connect to the webclient of PBX2.
If the network PBX1 uses cannot see PBX2's https port then it wont work. And vice versa.
Both the 3cx server are hosted in the cloud one in amazon(Master) l and other in another cloud data center(Slave)
Now I am able to see the presence of the slave 3cx server extensions from Master 3cx server web-client but not able to view the Master 3cx server extensions presence on slave 3cx server web-client
Reactions: Connexium Partner
Then you were typing the wrong port in the the PBX B's Presence page.
Go to PBX B (not the Amazon machine) and in the Presence page, remove :5001 and give it a few moments to reconnect.
JohnS_3CX
Thank you very much it worked now I able to view the presence of both 3cx server extension over Bridge connection
Reactions: JohnS_3CX
You're welcome, glad to hear all is well now!
EMMEPICASA
