Fanvil 3x Provision Parameters
TheCourierr
I would like to know if there is a documentation that includes all the provision parameters of fanvil phones like there already is with yealink.
I have a used provision that use this type of parameters for an example:
VOIP_CONFIG_FILE->SIP_CONFIG_MODULE->SIP_Line_List->SIP_Line_List_Entry->Enable_Reg
So i need to find the parameter for connecting to SIP server via TLS and enable SRTP. I only found how to do it on the web interface but i need to do it via provision as i have 50 devices to do this.
I take it that your system is not 3CX Free or 3CX SMB (3CX startup) as per the section this is posted under.
When provisioning phones remotely, the 3CX system is designed to work with a 3CX SBC installed on the remote side (phones side) to provision IP phones. The communication will, therefore, use the 3CX tunnel via TLS and Tunnel encapsulation.
gmacinit
