Unsupported Fanvil C62 - Phone displays Update Done/Update Failed every couple of minutes
IanFarrugia
I have a Fanvil C62 connected to 3CX, registered on ext. 103. Every couple of minutes, it displays "Update Done" which is then followed by "Update Failed" a couple of seconds later. I've tried searching for a fix but I haven't found a similar problem to this. I tried updating its firmware to the latest one (2.5.787.97) but it didn't fix the problem.
It could be that the problem is that when I added the phone to the extension in 3CX, I chose "Fanvil C600" from the list, since "Fanvil C62" wasn't listed in the phone list and this was the closest to it. However, I couldn't find a way to add this phone to the phone list. Despite using C600, I can still use the phone properly, allowing me to do calls.
Can anyone help me solve this problem, please?
Thank you
As this isnt a supported device you would need to visit Fanvil's website and get the latest firmware from there and manually install it on the phone.
I've already done this, but the phone keeps displaying the same problem.
Time to get a new phone.
If you insist on using the unsupported phone your best bet will probably be to manually configure/register it and leave the extension configured with just the app or make a custom template for the phone.
We have manually registered Snom C620 conference phones but they don't need changes like BLF keys often.
LeeonLau
