Solved Fax problem
Andriy
Forum User
Hello
I have setup a dedicated FAX did so that when a fax is sent to this DID it goes to 88 extension and converted to PDF and sent to the email specified in FAX server settings. It worked a couple of times, but recently for some reason I am getting an error.
I can not send faxes to this DID,
When I call the number a get a voice message (system prompt)
SERVER_ERROR internal_servererror.wav
when t38 fallback is disabled and
DEST_NA destnot_available.wav
when t38 fallback is enabled.
Anyone has an idea on why this happens?
thank you
Hello @Andriy
Try sending a fax to the specified DID and check the activity log to see what is causing the issue. You could also try restarting the IVR server service form the Dashboard / Services and see if that helps with the issue.
Does your provider support T.38 or Audio faxing ?
Reactions: Andriy
Hello, YiannisH_3CX,
My VOIP provider does not support t38. So i am using g711
I will try restarting IVR now.
Restarting IVR helped.
Thanks so much!
Glad to see the issue has been resolved. Keep an eye on the issue and let us know if you face something similar in the future
Bluebox Global
