Unsupported Fax to mail with incoming cisco sip trunk
Hostname
SOHO User
Hello team,
I have cisco cube and i want to enable the feature of fax to mail incoming call works but i want to know if possible to make a fax to mail?
Personally I avoid fax. I use a fax to email service from clearlyip.com that was a suggestion from reddit. I think they call it sendfax or something like that.
@Hostname
If the Cisco cube is essentially added as a SIP Trunk on the PBX you can just route faxs to a specific DID to 3CX's FAX server: https://www.3cx.com/docs/manual/fax-server/
Hello i Get this error from the ISP ( ISP has a cisco two)
Is that the ISP not support T38 ?
Here is the architechure:
ISP (cisco CPE)-->SIP TRUNK-->Cisco cube-->SIP TRUNK-->3cx
The SIP response code 488 is usually due to CODEC mismatch. If your not sure if your provider does T.38 you can try enabling "Enable G.711 to T.38 Fallback [BETA]" as an option. But I got no experience doing this, just a suggestion.
Hello i think that the provider not enabling T38.
Jake R
