Feature Request: Yealink daylight savings options.
Valkrey_Jatelle
Hi There.
I don't know about everyone else but all of our clients over here in australia are having the same issue with DST.
It appears that 3cx sets the dst option to automatic, and the phone believes we still partake of DST.
Would be great to have an option to change that to disabled or enabled, in 3cx.
So that when the phone is reprovisioned, as all of ours are every night, they retain the correct settings.
Regards
Which Yealink? Are you using default templates? I believe the phones take their time from the 3CX - Have you got the correct timezone set in your PBX? Or, are you using an NTP server in DHCP?
The phones actually take their time from pool.ntp.org but they will adjust their DST based on the settings they are provisioned with, and within the limits of the firmware the manufacturer has designed.
Please note that in Australia it's divided in territories and there is more than one timezone, and some observe DST whilst others don't.
The PBX global timezone allows for these, and the phones also allow for this (manufacturer and model dependent)
Cloudstar
