Final Stop to V20: Release Candidate 3
well, I deleted and reprovisioned again fanvil phones and now it seems to work!
digital misteries...
Like in the personal greetings options...
In Fact, it could be great to have this everywhere in PBX audio needs to be recorded,GRP, IVR, Qs etc...
absolutely
I'm currently running 20.0.0.1494, attempting to update to 20.0 RC3 20.0.0.1609 .The update never finishes. No messages or e-mails, just the update page says "Disconnected. Reconnecting in <X> seconds>" Starts at like 20, counts down, the goes to 30, then counts back down, etc. Different browsers, different computers, etc - cannot access the web interface. Any suggestions on what to look for / what log files to look at ?
Let it run for 2-3 minutes, it took a while for us too.
Ohh, that's odd. What's the specs of the machine?
It's a Vultr cloud hosted computer:
Model name: Intel Xeon Processor (Cascadelake)
BIOS Model name: pc-i440fx-7.2 CPU @ 2.0GHz
BIOS CPU family: 1
CPU family: 6
Model: 85
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Stepping: 6
1GB ram , 25GB HD
BIOS CPU family: 1
CPU family: 6
Model: 85
Socket(s): 1
Stepping: 6
1GB ram , 25GB HD
How were you able to upgrade to v20? V20 requires 2 cores minimum with a recommended 2GB of RAM.
Oh?
I'm not sure... Ok.. let me see if I can switch it to a dual core VM.
Upgraded VM:
vCPU/s:
2 vCPUs
RAM:
2048.00 MB
Still same issue attempting to upgrade
15GB free.. I get no e-mails. I can let it run over 30 minutes if it'd help?
kvm
Filesystem Size Used Avail Use% Mounted on
udev 965M 0 965M 0% /dev
tmpfs 197M 644K 197M 1% /run
/dev/vda1 24G 8.3G 15G 38% /
tmpfs 984M 1.1M 983M 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
V20 - Considerations in connection with Bridge.
We host a 3CX that is Bridged together with 2 other PBXs that we do not manage. It would be very useful if we could see the 3CX Version on the other servers in the Bridge configuration, so we know if it is time to update to the latest version or if we have to wait.
It can also be an advantage to have a standard selection box so that we can choose whether all newly created agents can see presence by default.
Thank you in advance
Hello.
I'm currently thinking about how I can set my own times for extensions, like in V18, without changing the status?So far I have only found the possibility of setting your own times under the extension, but as described there, the status is changed.In the detailed rules, I was able to deal with the extension here, but the extension was not treated here, which in my opinion was correct here, because there are situations in which the extensions have, for example, 7:30 a.m. to 12:00 p.m. as telephone hours, but the extensions from 7:30 a.m. to 4:00 p.m.Why is there a difference? The employees should only be reachable from outside during a limited time and should be reachable to each other during office hours.In plain language, office hours are not telephone hours.
Bye
Timm
How can i configure fax2email in v20?
Any other suggestions on what to look for? Same thing now with a dual core vm.
Consider to contact your partner.
Otherwise you could install from scratch and restore a backup. Quick and easy
Cloudstar
