Solved Forward to mobile has issues: Target endpoint can't be built
Arthur Siu
I posted last week about my problem which was when I asked 3cx to forward to a number, that it would fail. Even though I could call that number manually without any issue.
So I figured out where the Activity Log was and found these entries.
[Flow] Target endpoint for xxx-xxx-xxxx can not be built!
following that afterward
[CM303006]: There's no outbound rule for external number 'xxx-xxx-xxxx' defined
Any ideas what's happening?
Yes, exactly what it says:
That's a pretty clear message
Haha ,thanks for your sarcasm.
Anyways I figured it out, though it's mainly my own stupidity
When I type a phone number with dashes it doesn't recognize it. Simple as that. Just shoot me.
Glad to see the issue has been resolved and thank you for updating the post with your solution.
