Solved forwarding rule problem
bashrael
Forum User
Hi we have a 3cx cloud server with 3 remote stun extension on 1 site.
Incoming calls work ...extension starts ringing. But after 30 seconds the call should be forwarded to a group with the 2 other extensions.
The forward doenst happen en the call just ends.
I can't find what is causing this.
This is the log:
Code:
03/07/2019 4:44:34 PM - Currently active calls [none]
03/07/2019 4:44:25 PM - Leg L:61.2[Extn:02] is terminated: Cause: 487 Request Terminated/INVITE from 78.2x1.61.2:5060
03/07/2019 4:44:25 PM - [CM503003]: Call(C:61): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 78.2x1.61.2:5060
03/07/2019 4:44:25 PM - [CM503008]: Call(C:61): Call is terminated
03/07/2019 4:44:25 PM - Leg L:61.1[Line:10000<<09277xxxx] is terminated: Cause: CANCEL from 188.66.x.x:5060
03/07/2019 4:44:04 PM - Currently active calls - 1: [61]
03/07/2019 4:43:56 PM - [CM505001]: Endpoint Extn:02: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Fanvil X4 2.8.0.6251 0c383e1d3f27] PBX contact: [sip:[email protected]:5060]
03/07/2019 4:43:56 PM - [CM503002]: Call(C:61): Alerting Extn:02 by contact <sip:[email protected]:5060>
03/07/2019 4:43:55 PM - [CM503025]: Call(C:61): Calling T:Extn:02@[Dev:sip:[email protected]:5060] for L:61.1[Line:10000<<09277xxxx]
03/07/2019 4:43:55 PM - [CM503027]: Call(C:61): From: Line:10000<<09277xxxx ("09277xxxx:Inkomend" <sip:[email protected]:5060>)  to  T:Extn:02@[Dev:sip:[email protected]:5060]
03/07/2019 4:43:55 PM - [CM503004]: Call(C:61): Route 1: from L:61.1[Line:10000<<09277xxxx] to T:Extn:02@[Dev:sip:[email protected]:5060]
03/07/2019 4:43:55 PM - [Flow] No office hours set, office hours assumed
03/07/2019 4:43:55 PM - [Flow] Call(C:61): has built target endpoint: Extn:02 for call from L:61.1[Line:10000<<09277xxxx]
03/07/2019 4:43:55 PM - [Flow] Target endpoint for 02 is Extn:02
03/07/2019 4:43:55 PM - [CM503010]: Call(C:61): Making route(s) from Line:10000<<09277xxxx to <sip:[email protected]:5060>
03/07/2019 4:43:55 PM - [CM505003]: Provider:[Sip Trunk 3starsnet] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3StarsNet VoipSwitch] PBX contact: [sip:[email protected]:5060]
03/07/2019 4:43:55 PM - [CM500002]: Call(C:61): Info on incoming INVITE from Line:10000<<09277xxxx:
Invite-IN Recv Req INVITE from 188.66.x.x:5060 tid=e23d.955241d8fc5132b71094e8bb7d3b5f14.0 [email protected]:5060:
INVITE sip:[email protected]:5060;rinstance=3e29a7ce0d4ff1a4 SIP/2.0
Via: SIP/2.0/UDP 188.66.x.x;branch=z9hG4bKe23d.955241d8fc5132b71094e8bb7d3b5f14.0
Via: SIP/2.0/UDP 188.66.x.34:5060;received=188.66.x.34;branch=z9hG4bK036ee4d8;rport=5060
Max-Forwards: 69
Record-Route: <sip:188.66.x.x;lr=on>
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>
Call-ID: [email protected]:5060
CSeq: 102 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Content-Type: application/sdp
Date: Thu, 07 Mar 2019 15:43:55 GMT
Supported: replaces, timer
User-Agent: 3StarsNet VoipSwitch
X-Enswitch-Uniqueid: 1551973435.493054
Diversion: <sip:093363164@ast27>
X-Enswitch-RURI: sip:[email protected]:5060
X-Enswitch-Source: 188.66.x.34:5060
X-Enswitch-External: yes
Content-Length: 366
v=0
o=root 78819347 78819347 IN IP4 188.66.x.x
s=3StarsNet VoipSwitch
c=IN IP4 188.66.x.x
t=0 0
m=audio 17316 RTP/AVP 8 0 18 3 9 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:3 GSM/8000
a=rtpmap:9 G722/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
a=sdpmangled:yes
03/07/2019 4:43:55 PM - [CM503001]: Call(C:61): Incoming call from Line:10000<<09277xxxx to <sip:[email protected]:5060>
03/07/2019 4:43:55 PM - Line limit check: Current # of calls for line Lc:10000([USER=45620]@sip[/USER] Trunk 3starsnet[<sip:[email protected]:5060>]) is 1; limit is 10
03/07/2019 4:43:55 PM - [CM503012]: Inbound specific hours w/o holidays rule (Inkomend) for 10000 forwards to DN:02
03/07/2019 4:43:55 PM - [Flow] Looking for inbound target: called=093363164; caller="09277xxxx" <sip:09277xxxx@:5060>
03/07/2019 4:43:34 PM - Currently active calls [none]
03/07/2019 4:43:04 PM - Timezone offset: 60 min.
any advice/ideas?
thanks!
Who has this IP? Have you tried any other forwarding from the Extension, does that work?
Hi, thats an ip from the sip provider.
No not yet tried that. There only 3 extensions in this 3cx pbx. But i could try to forward to an extension instead of a ring group.
IIf we change the forwarding time from 30 sec to 15 sec the forward works.
If change the time to 30 sec again the call ends after 30 sec.
What could this be?
the provider is ending the call before your timeout expires if the above is indeed correct
Reactions: craigreilly
I tried forwarding to an extension in stead of a group and the result is the same.
I sended a log to our provider to check out whats happening on their side
Ok, let us know what the provider responds
Your provider will have to confirm, but it would appear that they terminate unanswered calls after a set time. I have seen some do this to prevent lost calls, that simply remain "up", for some reason, tying up resources. Hopefully they can increase the time for you.
Hi all,
So it was the sip provider.
After 30 seconds they sended the call to failover.
After adjusting this everything works fine now.
Thanks all.
Glad to know it has been resolved
GP Concepts
