Solved Forwarding to external number
Bly
Hi all,
on version 16.0.655 (hosted on Windows) I'd like set up the (standard) digital receptionist to forward to an external number some keys.
As long as the option "forward to" is not there, I had created an extension with mobile number the number I want to forward to (I call a landline number, does it matters?), and did setup in receptionist the rule "connect to extension".
Tried to test this setup, and when I press the key that triggers this rule, I get just 2-3s for wait music, and then the answer "voicemail disabled for this user".
I'd like the forward giving the called number the time for answer, maybe 20s or alike.
Can you please help me on finding the place(s) I have to look for, and any settings I have to be sure have setup correctly, in order to achieve the expected result?
Here is the call log, if may help:
10/02/2020 12:18:55 PM 345xxxxxxx:RST (345xxxxxxx) VMail (04) 00:00:03
10/02/2020 12:18:55 PM IVR (IVRForward) +3902xxxxxxxx Not Answered
10/02/2020 12:18:54 PM 345xxxxxxx:RST (04) +3902xxxxxxxx Not Answered
10/02/2020 12:18:54 PM 345xxxxxxx:RST (345xxxxxxx) IVR (IVRForward) 00:00:01
10/02/2020 12:18:53 PM 345xxxxxxx:RST (345xxxxxxx) Centralino Esterno (04) Not Answered
10/02/2020 12:18:45 PM 345xxxxxxx:RST (345xxxxxxx) IVR (20) 00:00:08
TIA, Andrea
Most probably this is your outbound rule which is not enough relax to let system extension able to do external forwarding.
rule need to be without groups or extensions
Reactions: YiannisH_3CX
You did nailed the issue at first glance :)
The newly created extension did not had the rights to forward to external numbers.
Thank you for help!
You're welcome :)
Robert Lee
