Google Drive alternative
DaveA66
Platinum Partner
Does anyone have any suggestions for alternatives to Google Drive?
We have a client backing up call recording and they need 6 years of archive, which with their call rate will be about 1TB
Some of the cloud FTP providers are eye wateringly expensive compared to gDrive
Cheers!
Dave
Hi Dave,
Soon enough we will add options for SFTP and SMB, and a bit later on we will also add support for buckets which should a more cost effective solution.
GDrive is effectively deprecated now due to changes made on google's side that make it very difficult to keep using it. Read more about it here: https://www.3cx.com/blog/docs/backup-google-drive/
martin99
