- Joined
- Jan 29, 2019
- Messages
- 12
- Reaction score
- 0
I've sent a message to your support, but this is just a heads up for a larger audience.
If you update the kernel on the Lightsail (maybe AWS instances are susceptible too) v16 instance it will show up as running but no SSH/HTTPS/SIP connections will be possible.
Steps to reproduce:
1. Use Express setup to roll a brand new 3cx instance on AWS.
2. Run
I have (sadly) tried it with both alpha and current release versions of 3cx.
PS. This is happening in us-west2 region.
Steps to reproduce:
2. Run
3. Ensure that neither SSH nor HTTPS, SIP connection is possible.sudo apt-get update; sudo apt-get upgrade; sudo apt-get install linux-image-amd64; sudo reboot;
